AH FabricationsEM Tuning
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Broken Byzan
Thread: Timing or cam sensor please help
    Jul 2013
    Sussex
    41
    Angry Timing or cam sensor please help
    Hi to all. I've got a s3 2000 apy and has bad judder/ misfire. Scanned with vag-com and got code 17745/p1337. I've changed the cam sensor and check power to the connector reading 5v I have not checked the switch wire. The cambelt was change about 3 weeks ago could it be the timing out????
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    17745/P1337/004919 - Ross-Tech Wiki
    17745/P1337/004919 - Camshaft Position Sensor (G40)
    17745/P1337/004919 - Camshaft Position Sensor (G40): Short to Ground
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Camshaft Position Sensor (G40) faulty
    Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
    Possible Solutions
    Check Camshaft Adjustment
    Check Camshaft Position Sensor (G40)
    Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
    Double check the wiring... its shared wiring on these... if you unplug the sensor, turn on ignition, clear codes and turn the engine over do you get an open circuit fault code instead? if you do then I suspect its a wiring fault in the loom somewhere... no other fault codes?
    <tuffty/>
    Jul 2013
    Sussex
    41
    Hi thanks for quick reply. I get the epc light come up then clear all codes then goes away. Yes it's the only code that I get. I shall try what you have said and post my results. Once again thanks
    Jul 2013
    Sussex
    41
    I'm getting code 17746/p1338-35-00-- open or short to plus. Is this a big problem I've got on my hands??? Also is it safe to drive with this fault??
    Jul 2013
    10
    Ive got a cam sensor for one drop ne a pm 10 £ posted
    Jul 2013
    Sussex
    41
    Thanks for the offer but I've tried two new ones just in case one was bad.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    badly timed engine. Take it back to the garage to get it checked.
    Apr 2004
    12,503
    Had this with hollies car, it was a timing error. It couldn't see the cam where it expected so it threw the fault. No idea why it didnt throw the correlation code, have to assume it was related to VVT. I think it was cam to cam over crank to cam. But given they have recently changed the cam belt, my bet it the error is there.
    Possible Symptoms
    Possible Causes
    Possible Solutions
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    Quote Originally Posted by Byzan Pics View Post
    I remember this now yeah... good spot dude
    <tuffty/>
    Jul 2013
    Sussex
    41
    I was thinking it may be timing ill give them a ring in the morn. Thanks for your advice.
    Jul 2013
    Sussex
    41
    Dose my apy have vvt-I? If not could timing be the strongest possibility???
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    No it doesnt have vvt
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I had this and the belt was out, god knows why it throws a short to ground code, anyway corrected it and was perfect..
  1. Continuous Engine Coolant Temp. Sensor Problem - PLEASE HELP!
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2009, 15:25
  2. '99 2.5 AFB V6 TDi Timing problem!! Please help
    By owais2k in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th November 2009, 13:19
  3. Great timing! S3 playing up, please help
    By s3vik225bhp in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 21:26
  4. A6 Parking Sensors-please help
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th June 2006, 18:54
  5. please help wrong time
    By sbanjac in forum Classic Audi Forum
    Last Post: 14th June 2004, 13:20
