EM TuningAH Fabrications
Thread: Cam belt
    Jul 2013
    21
    Cam belt
    Hi do i need to replace cam belt damper when doing the belt, I brought a cam belt kit and got pulley etc and got told not to do damper
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Yes, get a damper... and a water pump if you haven't got one with the kit...
    VAG don't spec a damper as part of a cam belt change but I have seen these fail shortly after a cam belt change... never worth risking it when there is so much at stake...
    Last one I got for mine came from GSF and is essentially a VAG one with the 4 rings machined off...
    <tuffty/>
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Definitely change the damper I had a very lucky escape last year when mine started to rattle, sounded like an exhaust heat shield was chattering, fortunately garage spotted real cause before it let go and trashed my engine. As Tufty says do the water pump at same time
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Jul 2013
    21
    Got water pump, what are your opinions between metal and plastic?
    just finished rebuilding the head and putting back together after belt failed so don't want to risk it
    Thank you
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Personally would just buy an OE plastic ones... yes they used to fail but the new ones appear better and all metal impeller pumps I have seen leak through the shaft very quickly
    <tuffty/>
  1. 1.8T Cam-belt tensioner differences?
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2004, 22:50
  2. Cam belt!
    By leespears1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 14:17
  3. S4 Cam Belt
    By duane in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2004, 08:01
  4. CAM BELT?
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2004, 16:32
  5. Cam Belt Tensioner - Known Issue??
    By Anito in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th March 2004, 07:55
