Error Codes and general advice
Steve Welch
Ok so my A3 that i bought on a limb has 4 error codes. It is a 1.6 1998. I looked in the section for help but it was not coming up.
So the codes are
00537 Oxygen Sensor Control
00557 (no code found in the manual)
00525 02 Sensor - Voltage Low - G39
00668 Battery Power Voltage Supply (terminal 3)
So does this mean i must replace the Lambda Sensor (i am guessing there is only one in the front downpipe)
It is idling a bit rough and is stalling VERY easily.
Any help or advice or help would be greatly appreciated. Remember i am a relative noob so idiot speak would be preferred! :salute:
If you type the code into google one of the first results is for Ross techs site were you will find the info your looking for
I have studied all of them further and i think my two first port of calls are:
1: New battery
2: Pre cat lambda sensor.
Here are a few pics of more findings.
After running/starting this appears on the ground from the exhaust
There is this sludge in the top of the coolant that doesn't smell of anything.
This is one of her bad starts:
Hey buddy, i did check for leaks and it all seems good as i had a leak in my mazda before and it turned out to be a split in the air intake.
I had a read of that and i think it is all coming together. Very soon i will have her on the road. I am in Cowdenbeath but i was brought up in Glenrothes.
00557 - Ross-Tech Wiki
00557 - Pressure Switch; Power Steering (F88)
00557 - Pressure Switch; Power Steering (F88): Short to Ground
Possible Symptoms
Engine shuts off while steering
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Power Steering Pressure Switch (F88) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Power Steering Pressure Switch (F88)
Check/Replace Power Steering Pressure Switch (F88)
Codes resource available here..
Category:Fault Codes - Ross-Tech Wiki
Also worth a read
http://www.audi-sport.net/vb/a3-s3-...-help-please-read-before-posting-updated.html
<tuffty/>
458
