Chris NottMonster Motorsport
    Jul 2013
    Error Codes and general advice
    Ok so my A3 that i bought on a limb has 4 error codes. It is a 1.6 1998. I looked in the section for help but it was not coming up.
    So the codes are
    00537 Oxygen Sensor Control
    00557 (no code found in the manual)
    00525 02 Sensor - Voltage Low - G39
    00668 Battery Power Voltage Supply (terminal 3)
    So does this mean i must replace the Lambda Sensor (i am guessing there is only one in the front downpipe)
    It is idling a bit rough and is stalling VERY easily.
    Any help or advice or help would be greatly appreciated. Remember i am a relative noob so idiot speak would be preferred!
    dusty's Avatar
    Nov 2010
    nw england
    143
    If you type the code into google one of the first results is for Ross techs site were you will find the info your looking for
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    Jul 2013
    Quote Originally Posted by dusty View Post
    I have studied all of them further and i think my two first port of calls are:
    1: New battery
    2: Pre cat lambda sensor.
    Here are a few pics of more findings.
    After running/starting this appears on the ground from the exhaust
    There is this sludge in the top of the coolant that doesn't smell of anything.
    This is one of her bad starts:
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    635
    Quote Originally Posted by Steve Welch View Post
    have a read on this. 1.6 AEH Engine - Idling Problem - Page 2
    where in fife are you?
    what miles is on your car? have you checked for vac leaks or any air leaks?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Jul 2013
    Hey buddy, i did check for leaks and it all seems good as i had a leak in my mazda before and it turned out to be a split in the air intake.
    I had a read of that and i think it is all coming together. Very soon i will have her on the road. I am in Cowdenbeath but i was brought up in Glenrothes.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    00557 - Ross-Tech Wiki
    00557 - Pressure Switch; Power Steering (F88)
    00557 - Pressure Switch; Power Steering (F88): Short to Ground
    Possible Symptoms
    Engine shuts off while steering
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Power Steering Pressure Switch (F88) faulty
    Possible Solutions
    Check Fuse(s)
    Check Wiring and/or Connector(s) from/to Power Steering Pressure Switch (F88)
    Check/Replace Power Steering Pressure Switch (F88)
    Codes resource available here..
    Category:Fault Codes - Ross-Tech Wiki
    Also worth a read
    IMPORTANT! - When posting asking for help... - PLEASE READ BEFORE POSTING (UPDATED)
    <tuffty/>
  1. 2007 B7 S4 Error codes and problem
    By ricostuart in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th February 2013, 12:53
  2. Error codes p3105 and p19561
    By vinnyl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2009, 12:23
  3. Help with error codes P1103, P0139 and P0411
    By royster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2007, 22:12
  4. Audi A4 1.9 TDI 110 - General Info and Buying Advice Please :)
    By DelBoyUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2005, 12:26
  5. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
