EM TuningChris Nott
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Clutch and dmf for a3 quattro
    Looking into a stage 2 map in the near future. My clutch isn't slipping at the moment but I want it done before the map,
    Is an s3 clutch the same as a 5spd a3 quattro? I'm struggling to find a clutch and dmf for the quattro can anyone recommend some product or retailers, thanks
    Oct 2008
    188
    Yes the a3 Quattro 5 speed gearbox is the same casing as the 6 speed so you would need a clutch that fits an s3 the standard s3/tt clutch would be up to the job of a stage 2 map also if you ever need a speedo sensor that goes in the gearbox you also need the 1 for a six speed box even thou it's a 5 speed they are different
    James TQ's Avatar
    Apr 2012
    Essex
    546
    so i can buy a s3/tt clutch and dual mass fly wheel? do i need a new speedo sensor is it a must? if the clutch says s3 6sp it will fit the a3 quatt? thanks pal
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by James TQ View Post
    do i need a new speedo sensor is it a must?...
    This is your answer....
    Quote Originally Posted by djdougalno1 View Post
    also if you ever need a speedo sensor....
    djdougalno1 was saying that should you ever need to buy one then you could source one from a 6 speed box as the 5 speed box in your A3 quatty is an 02M 6 speed box with 6th gear missing...
    <tuffty/>
  1. S3 ITG Intake, MV Sport Downpipe/Sports Cat, Standard Clutch and DMF.
    By Y444GAR in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2011, 18:20
  2. HELP! Clutch and flywheel 1.8T Quattro
    By Don's A3 TTu in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2010, 21:31
  3. Sachs Clutch and SMF for S3
    Last Post: 10th August 2010, 09:20
  4. Clutch and DMF
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd August 2010, 08:15
  5. which clutch and flywheel for 350bhp s3??
    By homer_s in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2008, 14:06
