Badger5Sky Insurance
Results 1 to 12 of 12
    boothy1994's Avatar
    Apr 2013
    Somerset
    36
    Follow boothy1994 On Twitter Add boothy1994 on Facebook Visit boothy1994's Instagram Channel
    hazard switch relay
    I posted before about a problem with my indicators and its still not sorted, I have a good idea that its the hazard switch relay however I can't find the part anywhere, spoke to loads of breakers. the part number is: 8L0 941 509 K
    what does the letter at the end mean? cause I find the same part code other than the last letter :@ frustrating, don't wanna spend too much but it needs sorting. does anyone know where I can buy one or one that will work in my car. it's a 2000 a3 1.8l 3dr. please help
    boothy1994's Avatar
    Apr 2013
    Somerset
    36
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    They're only around £30-£40 brand new from Audi aren't they mate?
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    The ones in the pre-facelift and facelift are different, your part number appears to be facelift.
    When my indicators went all random/stopped I carefully opened the switch up, you just need to press two clips on either side, and using electrical contact cleaner and a fine sharp implement cleaned the relay / throw contacts.
    It has been working fine for over 4 months since cleaning it.
    According to ETKA 8L0 941 509 K was superseded by 8L0 941 509 L.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    BTW - don't get the 'H' model it's for pre-facelift.
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    DO not buy a new one!
    its such a easy fix to diy it.
    first what is the problem exactly? is it that they are flicking to fast? do the indicators work normally and its just the hazards?
    if so take the casing off the relay box should just slide apart with a few clips (cant remember did mine ages ago)
    inside there should be two relays, the right one is for hazards and left for turn signals. there will be a tiny switch which is the ticking noise you hear when indicating, get a tiny screw driver and scratch them up and maybe bend them a little so they are closer to the contacts however don't do it too much or your end up like mine and having annoyingly loud ticking haha and job should be a goodern it took me a couple of tries before i got it working 30min jobs tops saves £40
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,055
    Well done Tim, if only I knew this a couple of years ago!!!
    Hope you get it sorted mate and if not, just get a new one from Dealers or TPS if they serve you.
    boothy1994's Avatar
    Apr 2013
    Somerset
    36
    I got told this and I have tried, before it was the indicators were really random, sometimes they would only click maybe twice before stopping and sometimes they would blink really fast and the hazards worked fine. however after doing this the indicators don't work at all and the hazards still work. I think I must have separated the contact points too much
    Nov 2012
    Kent
    459
    try bending the contacts so they are touching then slowly seperate them a tiny bit, test it if they are on constantly then seperate a little more
    boothy1994's Avatar
    Apr 2013
    Somerset
    36
    so just bend that little piece of metal with the contact point on it so that it has less of a gap to travel? I will try, so fiddly trying to squeeze a screwdriver down in that little gap haha
    Nov 2012
    Kent
    459
    yeah thats it, yeah it is a bit fiddly but it saves you £40
    boothy1994's Avatar
    Apr 2013
    Somerset
    36
    well I did manage it with a bit of tin foil however it's did work then I put it all back together and now it's gone again, not working at all, I have a second hand one on order now for £11 but I'm not sure if its the connection at the back of the relay once the relay is sealed, might try and hold it in while I try the indicators
  1. Where is the turn signal flasher unit? (Not the hazard switch relay)
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th March 2012, 20:20
  2. A6 hazard switch / relay constant ticking noise
    By Damianevs in forum General Technical / How To
    Last Post: 16th March 2011, 22:51
  3. Hazard switch/flasher relay repair
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2011, 22:38
  4. Changing indicator relay / hazard switch
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2008, 13:02
  5. Where and how to replace hazard switch!
    By 663KAY in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2005, 18:30
