EM TuningVolks Autos
Results 1 to 9 of 9
Thread: Water leak!!!
    matt blowen's Avatar
    Jul 2013
    staffordshire
    111
    Add matt blowen on Facebook
    Water leak!!!
    Hi guys and gals, please can somebody tell me what the white box underneath the scuttle is? Water is going underneath it and flooding my footwell. I have looked at pollen filter and its bone dry as is the surrounding area. Thanks matt
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Drivers side? wiring loom coming out of it?
    <tuffty/>
    Jul 2013
    staffordshire
    111
    Yes thats the 1
    Jan 2011
    Glasgow
    226
    Quote Originally Posted by matt blowen View Post
    Yes thats the 1
    Ive just fixed my problem with my passenger footwell water leak. Problem was scuttle panel had dirt under it. Under the scuttle panel there is a clip the whole length that clicks to the windscreen mine was clogged with dirt which could not be seen outside in any way. Allowing water to drip onto the pollen filter and soaking inside. Made worse when the climate control was turned on it pissed out.
    Jul 2013
    staffordshire
    111
    Glad you fixed it, i did notice the motor when i wipped out the filter to inspect but mine was dry.
    Jan 2011
    Glasgow
    226
    I'm pretty confident it's your scuttle panel that's causing your leak if you remove both wiper arms and lift the scuttle the whole bottom of your windscreen with have slimed dirt pushing the panel up off the clip. On my case the passenger side was most effected.
    Jul 2013
    staffordshire
    111
    Ok thanks for the info i will have a good look when i get time.
    Jan 2011
    Glasgow
    226
    make sure you buy or get someone to use the correct removal tool for the wiper arms or it will crack your windscreen.
    Jul 2013
    staffordshire
    111
    Ive already took them off. I opened the arm up then wiggled free off the thread.
  1. Water leaks
    By Vorshprungdork in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2004, 14:52
  2. help - water leak!!!!!!!!
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2004, 08:39
  3. Water Leak in the Cabin
    By bampy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2004, 18:00
  4. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
  5. Help, S4 water leak!
    By Futureman in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2003, 20:11
