Results 1 to 9 of 9
    Jun 2013
    16
    Front drivers tyre looks flatter than the rest but all pressures the same?
    Hi guys,
    I have noticed that my front drivers tyre appears slighty flatter than the rest.
    Now, I run standard 16" alloys with radial tyres so I know it is normal for them to look as if they are flat but should there be a difference in appearance between the o/s front and n/s front tyre. I have triple checked each tyre pressure and they are both running 35psi.
    Is this difference in appearance normal or indicative of a problem?
    I have noticed that the engine is mounted more too the off side of the vehicle. Could it simply be a question of weight distribution or is that just wishful thinking?
    Any help/advice/ideas would be very much appreciated
    Cheers,
    Mike
    Jun 2011
    Great Melton Norfolk
    1,349
    Are all the sizes/profiles the same?
    Jun 2013
    16
    Yep, tyres are all the same size, same make, same model and same tread.
    Aug 2009
    Costa del Cardiff
    535
    Are you sure its not a winter tyre?
    Wish list; Milltek Cat back non-res exhuast, R32 roll bar, adjustable rear tie-arms, Powerflex polybush dog bone mount, XS Power Manifold, 3"DP, B5 TIP V2, & a Remap :D
    Jun 2013
    16
    Quote Originally Posted by JoeD View Post
    Even if they were winter tyres, it still wouldn't be normal for the osf to look lower than the nsf
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    the cars heavier at the front
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Weak damper/spring. Or you're parked on a slope
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Lay off the acid
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Hole in the ground where the wheel is..?
  1. Water puddle in the foot well back and front drivers side help
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2013, 14:44
  2. Looking to darken my grill but what's the best way?
    By bigblokey0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2012, 22:32
  3. Front Center Arm rest has locked in the up position ??
    By Q-spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2011, 20:41
  4. 1.8T LOWERED BUT HIGHER AT THE BACK THAN FRONT??? PICS
    By cossie in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st August 2010, 07:05
  5. anyone ever taken the foam cushions out of the front seats?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2006, 20:12
