AH FabricationsBadger5
    Dec 2011
    630
    Oil in this heat ??
    Went to check my oil and coolant and the oil needed a small top up so went in the boot and the oil out (5w30 platinum) and it was really thin will this be giving my engine enough protection on start up? Or should I switch to a thicker oil when the weather is as hot as this ?
    chaz20vt's Avatar
    Aug 2012
    425
    I'm no mechanic but surely the oil gets a lot hotter in your engine when it's running than it sitting in the boot
    Dec 2011
    630
    Quote Originally Posted by chaz20vt View Post
    yes I would like to think so lol,but because its so thin will it be giving the engine enough protection when starting after its sat for a while
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,275
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quantum Platinum 5w40 from TPS for me
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Dec 2011
    630
    I'm sure mines is 5w40 too made a mistake on the first post
  1. gearbox oil (will this be ok?)
    By matty907 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2010, 11:46
  2. is this oil ok ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th September 2007, 08:25
  3. Oil light warning resulting in toe home, anyone recognise this problem?
    By sam_20vturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2006, 19:02
  4. VID: This guys well 'oiled'
    By hop2407 in forum Jokes, Games & Humour
    Last Post: 27th September 2006, 14:59
  5. Oil Filler Cap - how could this happen??
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2006, 13:01
