Results 1 to 9 of 9
    Jul 2013
    Essex
    S3 8L Remap stage 1... Possible air/boost leak..?
    Hi all,
    I Just had a remap stage 1 to my standard S3 8L 225 taking it to c. 255b and 360n..makes the car a real pleasure to drive.. I was cruising in 3rd and 4th gear today at about 2200revs and when I put the gas down to accelerate there was a slight shhhhh sound that I've never heard before, which occurred between 2600 and 4000revs, and what seemed to be like a slight loss in boost/power.. Can anyone advise the cause and fix to this? Slight air leak possibly?..
    D
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Yes, so have a look for the leak, check all the boost pipes and clips. Smoke test will help hugely
    Jul 2013
    Essex
    Thanks Superkarl,
    I'll check for leaks tonight. Bit of a novice question but how do you get a smoke test?...
    RIP S3dave
    May 2004
    nr Glos
    7,166
    find a garage with the smoke test equipment..
    seems not many have them which amazes me, as they are so very usefull in finding leaks quickly
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2013
    Hampshire
    32
    I'm sat in the waiting room at MRC and they've just found a boost leak on my newly acquired S3
    Jun 2013
    Hampshire
    32
    Oh, and my turbo inlet pipe has a small leak.
    Anyone know where I can get one from......
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Quote Originally Posted by Searider View Post
    Badger5 mate above.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2013
    Hampshire
    32
    ........already ordered :-)
    Jul 2013
    Essex
    Thanks, I checked it last night and everything seems fine.. Going to take it into ZenSport later in the week to get a professional opinion form the guy who did my remap.. [maybe it's just the normal noise of the turbo etc that I've not been aware of before]
    Also, have got a Forge 008 diverter valve on the way as read these are a must upgrade after stage 1 as the stock DV doesn't hold the boost that well.. Is yellow spring the correct one to use?
  1. S3 AMK Stage 1 Remap Logs - Possible Boost Leak ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Weeks Ago, 17:22
  2. Possible Boost leak?
    By SteVR in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2010, 09:41
  3. Possible boost leak
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2009, 17:13
  4. Remap: Stage 2 vs Stage 1
    By MartayMcFly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2009, 22:52
  5. more boost leak possibilities....
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2005, 14:23
