Sky InsuranceEM Tuning
Results 1 to 13 of 13
    Oct 2008
    188
    Advice on where to find parts Manifold spacer and long studs
    Ok I'm looking to find an spacer to go between my head and exhaust manifold and some extra long studs obviously so I can fit the spacer if anyone knows where I can get these from would be great thanks
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    Why?
    Oct 2008
    188
    The mani fold and massive turbo Means the snail on the turbo just touches the block so I need a spacer just too give me the extra bit of clearance
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    I have a blank manifold header plate pm me ..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Where is it hitting? I had to grind a lump off the back of the block for mine....
    <tuffty/>
    Oct 2008
    188
    I did think about trying that but think I need that extra bit so that's why I wana get a spacer do u know if I can get longer studs thou
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    That fixing on the block serves no purpose dude... no 1.8t I have worked on (Ibiza's, A3, S3, Leons, Polo's etc... ) use this for anything... if this 'boss' is the thing stopping you fitting the turbo then get the grinder out... be more reliable than using long studs that could stretch and two gaskets...
    No idea on the availability of longer studs... guess they are available but you can't just use any old threaded bar else they will stretch from the heat and the manifold will come loose
    <tuffty/>
    Oct 2008
    188
    Mine looks like its either gona hit that water channel next to the lug you ground down or those three like lugs next to it what u think those three lugs are for
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by djdougalno1 View Post
    Pics will help...
    <tuffty/>
    Oct 2008
    188
    If you look in the pic you sent to the left of the lug u ground down there's a water channel to the left of that theres 3 small lumps on the block in a row going down I'm hitting them but I will try an get some pics tomorrow if that helps
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    The three where the middle one is already ground lower the the outside two? I suspect these would be ok the remove tbh but without looking on an actual block I wouldn't want to commit...
    There are a couple of scrap blocks at Bills but I am not there until next weekend so won't get a look until then...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Looking at the block I am using for my stroker build there are more of those jobbers on the side... may just be a visual indicator of some description rather than anything else so could be safe to remove...
    <tuffty/>
    Oct 2008
    188
    I suspect that they are from casting the block if they are in other places aswell then I might try and take a small amount out off them maybe sand the edge of the snail on the turbo aswell thanks for the help
  1. Where do you find part numbers?
    By Marky_Mark in forum General Automotive Chat
    Last Post: 11th March 2013, 18:39
  2. Replies: 3
    Last Post: 22nd June 2011, 18:44
  3. Advice needed on where to get parts
    By electric_cooper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2009, 22:12
  4. Where to find ignition live wire?
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2006, 19:38
  5. MAF element - where to find for Cable Driven AEB
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2005, 22:12
