Chris NottEM Tuning
    May 2012
    RETFORD, NOTTS
    1,753
    POS! Flickering speedo fuel and no more cruise control... whats the problem?
    Got my car back after having a replacement engine and recon turbo, drove away fine then the speedo started dancing, and the fuel guage too. Cruise control now no longer activates.
    Had a read and i dont want to accept that the ecu or cluster has spiked with battery connections etc, the earth under the battery was not disturbed apparently.
    Just got back from adapting a new set of clocks in a mk4 golf, so didnt fancy getting my vcds out again lol.
    Any suggestions on what to test and look for before i get off my backside and have a look!?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Sounds like the speed sensor in the gearbox to me...
    <tuffty/>
    May 2012
    RETFORD, NOTTS
    1,753
    <tuffty/>
    Do they go dicky and cause intermittent issues like this ? I just drove 120 miles with no hiccups but no cruise control
    measuring block 006 second field, 000 goes to 100 with clutch and 011 with brake, field 4 says 1 when on on the stalk on/off switch, and 0 when off but 17 when i hit the brake. is that normal?
    Is there anything else on the speed sensor loom? easy job to buy a new sensor?
    Its not so bad when im helping fix other cars, but fixing mine it becomes a pita lol.
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Glad to hear you got the engine sorted out pal.....
    Just hope you sort out the little niggles.
    Bet it's good to have her back on the road?
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    May 2012
    RETFORD, NOTTS
    1,753
    Yeah its a start lol, think it needs anogher blast through the hills to 'fix it'
    May 2012
    RETFORD, NOTTS
    1,753
    Well ill never use that garage again!
    Wiring and pipes all routed wrong, now re rooted, earths cleane, battery seated properly and terminals tightened!
    Seems to have fixed it , touch wood!
    Timing torsion value reads -1 though, think ill be getting it back into a specialist to retime it.
  1. speedo fault and fuel gadge going everywhere
    By MDG in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2012, 18:49
  2. Replies: 0
    Last Post: 29th November 2011, 20:30
  3. Retro fit cruise control (what do I need)
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2010, 09:23
  4. Cruise control retrofit.......but problem!
    By PiloTT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 18:04
  5. Trcky Subject and probably wrong forum ... but what the hell!
    By wigginer in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 18th January 2007, 20:42
