Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Fan Issues
    ollie2013uk's Avatar
    Mar 2013
    61
    Fan Issues
    Has anyone else had issues with the aircon and radiator fans not working on an 8L?
    Mine stopped yesterday, I checked the fuse and the one as you look at the box on top of the battery was worn / dirty. I cleaned it up with some wet and dry and the fans kicked in afterwards. Then later in the evening they didnt!
    Its obviously not a massive problem (i.e radiator doesn't need replacing) but nether the less its quite frustrating.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    If cleaning the fuse made them work then its the fuse/fuse box on top of the battery... this is a common problem... its not just the fuse thats corroded, the fuse holder will be too and this leads to higher current draw which melts it and can in some cases catch fire...
    <tuffty/>
    ollie2013uk likes this.
    Mar 2013
    61
    <tuffty/>
    Just been to halfrauds, got some 30amp fuses, replaced and all is OK. Doesn't fill me with too much confidence lol!!
  1. Cooling fan issue
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2012, 11:35
  2. s3 with posible fan issue??
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 21:35
  3. Newbie needs help - coolant fan issue
    By gnat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th June 2011, 12:46
  4. Car gone into dealers - fan issue!!!!
    By NICK-C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2010, 15:11
  5. A3 Fan Issues
    By AmanS7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 18:40
