Monster MotorsportEM Tuning
Thread: Dump valve
    May 2011
    stocton-on-tees
    64
    Dump valve
    Hi all just a quick one which is the best way to fit them as all the one I see r on a different way to my one if some one has any pic that will help me / baleys ones thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    There is only one way to fit them, boost in the side, bottom to the TIP... unless its a atmospheric valve then fit it in the bin and buy an OE valve... baileys valves leak like a sieve... you should read the "All you (probably) need to know about dump valves on 1.8t's" section in the FAQ's thread
    <tuffty/>
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
