Badger5Sky Insurance
    Mar 2011
    plymouth,devon
    10
    audi a3 1.8t quattro sport 180 ARY 2002
    HI GUYS.my car keeps throwing up the fault code 17939, which is either the camshaft sensor or adjustment valve.it does seems to idle a bit more rough than it used to.any ideas, as I dont want to replace the wrong part.a few times the eml light has come on.i dont know if thats to do with that or not.i have no other fault codes apart from this one.regards spence.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    17939/P1531/005425 - Ross-Tech Wiki
    17939/P1531/005425 - Camshaft Timing Adjustment: Open Circuit
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205) faulty
    Possible Solutions
    Check Fuse(s)
    Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205)
    Check/Replace Camshaft Adjustment Valve (N205)
    Check the VVT is plugged in
    <tuffty/>
    Mar 2011
    plymouth,devon
    10
    Thanks for pic.i take it connector on the right of the engine is what I need to check ? Thanks spence
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Yep...
    If its connected then check the wiring... open circuit suggests a break in connection so either not plugged in or a break in the wire
    <tuffty/>
  1. audi a3 1.8t quattro sport 180 2002
    By spencewatts in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2012, 21:55
  2. audi a3 1.8t quattro sport 180 2002
    By spencewatts in forum Forum Support
    Last Post: 29th December 2012, 17:02
  3. Audi A4 1.8T Quattro Sport for sale
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2006, 14:55
  4. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2005, 18:24
  5. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2005, 09:35
