Badger5Sky Insurance
Results 1 to 25 of 25
Like Tree4Likes
  • 2 Post By Gops
  • 1 Post By S3quatt
  • 1 Post By jojo
Thread: New car or walk away
    Jul 2013
    10
    Right guys have a 2001 s3 68k on the drive in loan from my motor trade mate, he said to try it for a bit.
    Issies ive found that donr want me to be out off and wondered if there were common issues. Here goes
    1) break pedal is near on on the floor before the breaks work, discs look poor tbh but didnt think that this wiuld cause that? Ideas?
    2) bits of bodywork need tarted up here and there.
    3) clutch has about a inch of play on pedal like slack before it does any thing and the clutch when ar say 3000rpm in 6th up a hill sdoes lift the revs a little then falls soni guess it needs a clutch.
    He wants 2300 for the car as a favour to me as he has it up for 3650...
    He will pay for the parts to fix but the clutch sounds like a pricey job
    Opinions please
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,635
    It's probably never had its clutch changed so that needs to be done. Brakes are probably the same so discs and pads and fluid should help the feel of the brakes. If he's paying for it all sounds good? The check for usual paint bubbling etc. more info is in the stickies section. I suggest you have a good read before you buy!
    Jul 2013
    10
    I will the top passange side were the 1/4 joins the roof has some bubbling. ..
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    Sounds like a cheap car if only 68k on it.... Other problems are nothing major... Cambelt will be due for a change... Do water pump as well.... Still not pricey... All depends whether you like it or not.... Usually gets you the minute you drive it and give it some beans.... Did me anyway....
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    The brakes and clutch pedal share the se fluid so perhaps it is low or needs bleeding.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dec 2011
    149
    Quote Originally Posted by cecilthesausage View Post
    needs a clutch , and could need a cambelt , and some body work , and you say a cheap car lol ,
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,635
    Every car needs a clutch and timing belt change, I rather buy a car that hasn't yet had it but for cheap. The reason is I've seen (and know) of dodgey people who are forging very legit looking receipts or getting their friends to print out an invoice for them when it hasn't even had it done! Or clock the mileage back with new MOT certs showing the new mileage and fake garage receipts showing the same mileage! Even been offered for mine to be done but what's the point? I bought my car at 150k because it was an honest car with shed loads of work done to it!
    thegoal007 and JudderMan like this.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Quote Originally Posted by Gops View Post
    And yours has been used instead of being laid up for months at a time. If a car hasn't done 12k miles a year then I'd worry.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Has you motor trade mate said that he will fix the problems then no matter what the price?
    I'm assuming he will do all the work himself or get someone else to do it for peanuts as he's in the motor trade? Other wise it will be pricey bill for the discs, pads, fluid and clutch kit all to be purchased and replaced.
    If you do take the car then the oil pick up pipe could probably do with being cleaned out or replaced as well tbh (£12ish).
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Mar 2013
    Slough
    84
    Check the Mileage the price and the mileage don't tie up that well IMO.
    Jul 2013
    10
    Yeah the oil pick up doesnt bother me, I had a clio running a 20vt so the engine im not so bothered about. Its the 4wd system that worrys me doing the clutch.
    Hell do the work him self but no doubt ill have to help! I dont mind I work for him on a Saturday doing clio belts on the 172/182s
    Ordered new breaks to be done today and neee to sort clutch regardless if I buy or not hell have to replace this stuff any ways
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    Quote Originally Posted by andyrg View Post
    Have a little read up here as to why I suggested the oil pick up pipe....
    AVS-Longlife Servicing, Engine Death as a consequence-Oil Pickup pipe etc
    Just a wild stab in the dark- but I'm going to guess your 20vt had a Forge Split R dump valve on it?
    2000 S3 APY
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,526
    Does it have a stack of service history to backup the mileage? For 2300 personally, I'd take a punt and fix it up to enjoy it, throw in a few subtle mods along the way. Running a car like an S3 is never going to be cheap anyways, it's a high performance hatchback! Bear in mind that after you have spent the monies to fix it, keep it for a while to make it worthwhile, and not sell it 6 months down the line and moan how much it cost you during that period!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,526
    It was a good, and still IS a good car!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,635
    Quote Originally Posted by jojo View Post
    bought it from a dodgey Chinese guy!
    funny enough one guy came up to me and days! "DVD fo sale! £2 each or 5 for £10!" And I thought Asians were dodgey! Lol
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Quote Originally Posted by JudderMan View Post
    I wouldn't. Mines only done 71k miles & has averaged between 5-6 K a year.
    I do have access to 3 other cars mind, but as the 2nd owner I know its a good 'un
    I would look for a stack of receipts or MOT history tho.
    16Klappe likes this.
    ...... Now this one's MUCH better!...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,526
    What you trying to say?
    Jul 2010
    Teesside
    933
    Quote Originally Posted by jimmcgee View Post
    Obviously what you class as cheap and what I class as cheap and what you pay for your work and what I pay for my work are worlds apart fella....
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,073
    Visit 16Klappe's Instagram Channel
    Personally....
    I wouldn't touch it for more than £1800.
    Regardless of mileage if a car hasn't been looked after it hasn't been looked after. An enthusiast car like an S3 SHOULD be faultless; if my brakes were spongey or my clutch had play then if would be sorted straight away. And I've only got a lowly A3.
    I would rather a 140k car with excellent history than a 70k car with faults.
    I quite often say I'm going to do things.
    Then never do them.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,526
    Quote Originally Posted by 16Klappe View Post
    Personally....
    Lucky the guys not selling to you then!
    Jul 2013
    10
    Car has full dealer history.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,073
    But still has fault.
    Doesn't add up, why maintain a 10 year old car at the main dealers but have a dodgy clutch and brake issues.
    Sure the history is genuine?
    Then never do them.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    I haven't had the best experiences when going to main dealers tbh.
    They don't come across as particularly knowledgeable or clued up about cars that are out of warranty and ageing; hence why even though it has full dealer history- there are still issues? Doesn't quiet add up.
    2000 S3 APY
    Jul 2013
    10
    I walked away from this. To many issues
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    595
    Thumbs up
    Wise choice I reckon! There are plenty more out there...
    As an example, I just put mine through its MOT yesterday & at 10 years old, it never even had one advisory.
    Properly looked after
  1. new car
    By ambiguous9898 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th April 2004, 04:08
  2. Audi / RAC cover - supplied with new car
    By Emma in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 03:59
  3. New Car - 4 or 3 stage that is the question?
    By wigginer in forum Detailing
    Last Post: 15th August 2003, 18:02
  4. MOVED: My new car
    By amoffat in forum General Chat
    Last Post: 2nd April 2003, 19:22
  5. Spotted . . . . .new cars!
    By Moresauce in forum Other Brands & Models
    Last Post: 30th January 2003, 13:25
