Badger5AH Fabrications
Results 1 to 17 of 17
    Jul 2013
    13
    Gearbox oil seal leak
    Kia ora everyone, I'm new here. After searching the net and posting on another forum, I have no answer. I'm in the process off a clutch replacement after the dmf failed and spat spring bits everywhere, and have come across an oil leak on the gearbox, don't know the technical name, is it driveshaft seal? I've uploaded a picture, is it simple to replace and does the socket have to come out? When I emptied the oil there was only about half a litre, is it likely the gearbox is buggered? Thanks alljo 002.jpg
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Year and model of car would help... that looks like quattro box? guessing you have an S3 or A3 TQS?
    There are three seal on the transfer box...
    As the gearbox needs removing to change the DMF then the transfer box will need to be removed for easier removal/refitting of the box anyway (special tool required to undo bolt down the centre of the drivers side drive flange)
    <tuffty/>
    Jul 2013
    13
    Hi, Sorry, it's a 2000 S3 AMK. The driveshaft seal certainly needs replacing but I don't know if the transfer small seal does (with the bush that fits into the gearbox) I think the oil from driveshaft seal just ran everywhere.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Replace them all... they weren't expensive but its a dealer part....
    Be persistent... took my local dealer a few attempts to get the right screen to show the seals... you may be lucky with your local dealer/TPS...
    <tuffty/>
    Jul 2013
    13
    Ok cheers. How do I go about replacing the driveshaft one on the gearbox? Does the driveshaft socket thingy come out?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by Henry2202 View Post
    There are three seals... if you look at the pic I posted earlier they are all attached to the transfer box... easy peasy... you do need a special tool to remove the bolt in the centre of the drive flange (transfer box side)... just undoing the four bolts won't remove it...
    <tuffty/>
    Jul 2013
    13
    So you're telling me where the transfer box shaft goes into the gearbox, that isn't an oil seal around it (on the gearbox)?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Not exactly... there are 3 seals... I have blown up the pic and indicated them with arrows... hopefully that should clear up any confusion..
    <tuffty/>
    Jul 2013
    13
    Ok thanks for that, I can see the ones you're talking about, I assumed this was the culprit (I've pointed it out) but from looking at your posts and knowledge I gather this can't be the problem? Thanks for your time.
    Jul 2013
    13
    Is that just the driveshaft seal? And does it just pop out?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Not sure what you are asking....
    The transfer box is held onto the gearbox by four large bolts and one 6mm headed allen bolt in the shaft of its drive flange... this 6mm bolt needs a special 6mm allen key tool thats long enough to fit down the shaft... see here
    Removing transfer box
    ...the transfer box is also supported at the driveshaft end by a support bracket that will need to be removed as well...
    Once the transfer box is removed (you will need to drain oil from the gearbox and the transfer box...) you will see 3 seals... thats about as complicated as that gets...
    I believe there is a seal on the drive shaft flange too but I never touched this when mine was off so can't comment on that one...
    <tuffty/>
    Jul 2013
    13
    I've got the gearbox and transfer box out, but there's oil all over each of them, so it's hard to tell what's leaking, so would it be wise just to change all 4 seals including the driveshaft seal?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Chances are this isn't the first clutch swap so the leak could be from a previous transfer box removal...
    Are you sure its gearbox oil? the cam cover rubber gasket is renowned for leaking and this oil gets everywhere over the box etc as it drips down the back...
    Personally I think the seals should be changed everytime... If you think it will leak or is leaking then change the seal... they aren't mega bucks especially compared to the agro of removing the box etc...
    <tuffty/>
    Jul 2013
    13
    Yep mate it's definitely gearbox oil, only half a litre or so was in the box as well, and it's new oil in there, the engine oil is a lot older, so easy to tell. Think i'll just change the lot for peace of mind because it's hard to tell which one/s leaking. thanks for the help
    Jul 2013
    13
    Tuffty, I've been given a link for the parts, to choose what seals but unsure what ones. Would you mind giving me some help please? Are you able to pm me? thanks
    Jul 2013
    13
    Or if you have the part numbers from when you ordered them that would be good. cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Replied in your other thread mate...
    Part numbers for S3 transfer box o-rings
    <tuffty/>
  1. Leaking Diff oil seals a4 quattro
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th May 2011, 19:51
  2. Audi a3 1998 1.t - leaking gearbox oil
    By Dudsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2010, 18:19
  3. Replies: 0
    Last Post: 19th June 2007, 16:44
  4. Leaking gearbox oil 2.5TDI with a manual 6 speed gearbox.
    By Joni_s in forum A4/S4 forum(B5 Chassis)
  5. gearbox oil leak
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2006, 10:52
