AH FabricationsBadger5
Thread: Esp
    Jul 2007
    6
    Esp
    Hi,
    Has anyone ever heard of the ESP light not flashing and cutting power when traction has been lost? I have read everywhere about the traction light staying on if there are errors in the haldex system but I cannot find any information about the ESP light not flickering on and off whilst cutting power when the wheels have lost traction and are spinning. If I push the ESP button the light comes on and stays on but nothing changes. I have ordered a new haldex pump and controller, as I know that my pump was not working. The car is a APY 2000 s3.
    Thanks,
    Marty
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,280
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Plug her into VCDS and see if any codes pop up.
    Correct with your research- if there is an issue with the ESP/Haldex then the light is usually on all the time :-\
    Have to just say that there can't be many APY 2000 S3s with ESP
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Oct 2011
    760
    mine has ESP that is permanently disabled,
    as above vcds check.
    Ditch the n249 if you havent already.
    Jul 2007
    6
    The n249 is long gone. Before the engine rebuild the esp triangle use to flicker and cut power to the engine but now the wheels can be spinning like there is no tomorrow but no flickering light and no cut in power? I have ordered the new haldex pump, as I know that it is not making any noise but is definately getting power as it has been checked. I just cannot explain why the esp light no longer flickers
    Oct 2011
    760
    small piece of black tape over the ESP light is the only thing i can think off that explains your problem.
    Jul 2007
    6
    Cant be the black tape as I can push the button and the light comes on.
  1. ESP turned off - no power coming out of a bend
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 14:47
  2. ESP - on or off?
    By munkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2003, 17:12
  3. ESP Warning Light
    By philyus in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2003, 21:54
  4. ESP over speed humps, but only in the wet?
    By elgjc3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2003, 13:55
  5. Thank Audi for Quattro/ESP
    By S3Bangs in forum General Chat
    Last Post: 10th January 2003, 09:26
