EM TuningChris Nott
Results 1 to 19 of 19
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    S3 gearbox like stirring a bag of bolts ...
    Hi
    I'm having a little trouble with the gear box on my 2001 AMK S3with 110k on the clock.
    Changing 2nd to 3rd crunches if I try to change up over with the engine over 3k. I have to let the engine revs drop below 3k to avoid a crunch.
    I've noticed when pulling up at traffic lights etc. I get a bit of a crunch block changing back down to first.
    I changed the gear box oil for OE Audi stuff about 3 months ago, I have check the gearbox oil level since this problem started and its fine. The problem has been occurring for about a month now.
    I've done some searching on the forum and it sounds like it could be :
    synchro going?
    engine/gearbox mounts?
    linkage cables?
    i don't know much about gearboxes so a little advice on trouble shooting or what to change / do first would be appreciated.
    Thanks. Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    What dogbone bush are you running?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    I would guess synchro if your having to let the revs drop down when changing up a gear
    What about changing down - do you have to blip the throttle?
    I rekon your having to wait until the input speed of the gearbox matches the output speed of the gearbox so that everything meshes nicely
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi Dave B,
    It's a standard OE dogbone, it's relatively new, being replaced in March/April 2012. The car has done <20k on this dogbone.
    Could it be that?
    Liam
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Alex C View Post
    No changing down from 4th to 3rd is 'ok', it requires a bit of a gentle push but nothing worrying.
    Dropping into first once at a stand still causes a bit of a clunk sometimes, it did it several times on the way to work this morning.
    Ta, Liam
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    tbh it sounds like my gearbox. I have to wait a while until i can change from 2 to 3 and from 3 to 4. On the way down i double de-clutch to try and rev match the gearchange
    If I'm only pottering about in the car then its not so bad, but if I'm on a mission then its the gearbox that hinders me, particularly changing down braking into corners
    I guess mine is worse than yours though. Mines been like that for nearly 20k miles
    Alex S3 AMK
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Alex C, you should work for Audi ... "They all do that sir!" ...
    I was wondering if it could be some dodgy fluid in the clutch hydraulic system causing the clutch slave to not fully extend?
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Im not saying it should be like that.... But i cant be arsed to get it fixed until it goes bang. I've had a new poly dog bone mount fitted, gearbox fluid changed once and then the second time gearbox fluid changed with a friction reducer added (molyslip) -- still the same............
    the scenario you mention would make me ask why a hydraulic issue with the clutch slave would only affect up shifting from 3 to 2 making it crunchy unless you rev match it
    Alex S3 AMK
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    the scenario you mention would make me ask why a hydraulic issue with the clutch slave would only affect down shifting from 3 to 2 making it crunchy unless you rev match it
    I know, I don't exactly understand the mechanics of hundreds of little spinning cogs and stuff in the gearbox so I didn't want to rule it out of my brain. (It's the up shift from 2 to 3 that's the real problem for me.)
    So it sounds like it's not the fluid or dog bone causing the issue.
    Have you changed the left or right engine mounts? or adjusted the shift cables?
    Liam
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Sorry, yes up shifting
    No, I haven't changed the engine mounts, that is on my list of things to do, even if it doesn't fit the crunchy gearbox it'll improve the feel of the car. I haven't adjusted the shift cables either
    Alex S3 AMK
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,279
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I doubt changing the engine mounts would help the problems you are having with your gearbox tbh mate....
    I recently had both of my engine mounts changed and they had seen better days in the 185k miles they had been used....but I didn't experience the problems you are describing before they were changed and I'm guessing my engine mounts would have been in a worse state than yours are given my mileage.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Mar 2013
    Devon
    613
    Defo try adjusting the shift cables, made a big difference on mine.
    There is a good guide on youtube. Costs nothing, easy job.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    I've just done the shift cable adjust/reset and it still crunches on 2nd to 3rd changes.
    Guess that leaves mounts or internal gearbox issue ...?
    Liam
    Mar 2013
    Devon
    613
    You could try a powerflex red (diesel version) bush in the dogbone engine mount. Probably worth a try for £20 before thinking about rebuilding the gearbox!
    Jul 2011
    57
    Add S3_DAVE on Facebook Visit S3_DAVE's Instagram Channel
    Quote Originally Posted by JimS3 View Post
    Hey Jim do you have a link to the video?
    Feb 2012
    Rutland
    132
    Quote Originally Posted by S3_DAVE View Post
    Look up "diesel geek gearbox adjustment" or similar and you will find it on youtube. On phone so not easy for me to check. Made no difference to my box though, so I eventually bought a second hand low mileage one and had it fitted.
    Cheers,
    Dan
    2001 AMK S3 in Goodwood Green
    Mar 2013
    Devon
    613
    Here you go, probably the best guide around:
    Shifter Adjustment - YouTube
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    I thought it had all settled down, I've not been driving the car much for a month or so, but the change from 2nd - 3rd still has issues when driven with sparkle.
    How difficult is a DIY gearbox change? I've found a replacement/used gearbox at a decent price. It's not been tested - seller has 'promised' it's in good nick but I'm on my own generally.
    To make the job easier I guess I need a lifting beam?
    My clutch is relatively new so I guess I don't need to remove/mess with that?
    Liam
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Just had my box swapped out as 1st and 2nd disappeared.
    It could be done at home I think but it wont be easy at all with basic axle stands etc as its a good 8-9 hour jobby using a lift etc. I was sorta lucky as my clutch was original so took the opportunity to replace this and the DMF whilst getting the box swapped over. I paid about £350 to a local independent garage to do the labour as I provided all the parts.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  1. A3 1.8T Occasionally running like a bag of hammers??? HELP!!
    By Andydos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2009, 10:54
  2. Idles like a bag of...
    By basscrazy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2009, 21:38
  3. a4 1.9 td sounds like a bag of nails
    By lorryloader in forum Diesel forum
    Last Post: 20th March 2009, 18:43
  4. Pinch bolt my arse, more like ******* bolt!
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2008, 23:43
  5. gearbox/engine mount bolt snapped!!!
    By Pete69zx in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2006, 12:22
