Thread: N249 hose leak
    May 2013
    Glasgow, Scotland
    195
    N249 hose leak
    Hi l had posted an earlier thread regarding a possible boost leak on my A3 2002 (8L) 1.8T AUM.
    After spraying easy start on to all the vacuum hoses i discovered that when i sprayed it on the hoses under the black metal plate infront of the inlet manifold, the car would rev a little higher.
    The background to the initial problem is a CEL with a MAF sensor problem and a system too lean on bank 1. I had the MAF replaced with a bosch 1 and the codes cleared. 3 days later the CEL is back on. The car feels like its hesitating on boost and it feels lumpy and rough. I have cleaned TB, Injector cleaner, replaced 1 coil pack.
    I was initilaly thinking o2 sensor, but have been put off and started hunting for a leak. I read on a thread about smoke testing, but could not find anyone to do it. So l found another thread and it suggested using starting spray. Hence i did and its coming from the pipes which l beleive are the N249 or N112.
    So i have been reading all night about the N249 delete and its pro's and con's. I dont know whats the best to do and if l could even do it myself ??
    I guess my question is could this change in revs when the spray was sprayed on these particular hoses be the cource of my problems, or am l way off ??
    Sorry to repost the same problem, but thought l would better explain and get as much help as l can !!
    Brendan
    May 2013
    Glasgow, Scotland
    195
  1. turbo hoses leaking oil?
    By maffew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2013, 18:00
  2. 'U' hose leaking.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2012, 17:55
  3. hose leaking....part no. please
    By a3Nate in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2011, 18:46
  4. N249 4mm vac hose clips?
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2011, 22:39
  5. Back washer not working.....leaking hose in rear quarter???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2008, 19:36
