Sky InsuranceAH Fabrications
Page 1 of 2 12 LastLast
Results 1 to 40 of 75
Like Tree6Likes
Thread: Will these wheels fit?
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    823
    Obviously will require some sort of offset adapters but just wondering if it is physically possible to fit this rim dimension onto the S3 8L chassis?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    dEpends on the pcd and the offset. Those figures are just width and diameter.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Look for the offset Shaun, needs to be between ET25-45 based on 7.5" rim, just to let you know that OEM 18s are 8" wide, but there's nothing wrong with running 7.5" wide rims. Stud patter needs to be 5x100 and centre bore 57.1mm off the top of my head.
    You've got to have a laugh!
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by jojo View Post
    Ok so they are coming off a A3 8P S line.
    How do I find pcd and offset to compare to the 8L?
    I take it the adapters are the same as wheel spacers?
    Dec 2009
    Chichester
    217
    PCD will be 5x112
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,100
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by ShaunS3 View Post
    I got my H&R spacers and adapters from DPM....being H&R there not exactly cheap though for a set of 4
    H&R Wheel Hub Adaptors & Bolts VAG 5/100 to VAG 5/112 - £125.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts for all VAG vehicles at the be
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Thanks dude.
    I know a local engineering firm that could make them up cheaper with high grade material.
    How do I know what spacing I need in mm?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    You need to know what offset they are first
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    A3 8P
    PCD: 5x112 Offset: 45-50 Bore: 57.1
    S3 8L
    PCD: 5x100 Offset: 35-38 Bore: 57.1
    Looking at the figures, i'm presuming they will fit with adapters no problem.
    How do i know what spacing i need in mm?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Use an online 'offset calculator'. Put your current wheel dimensions in, then the new wheel dimensions, and it will tell you how they sit. I.e. 20mm less 'poke', therefore requiring 20mm spacers to match your current wheels.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    I did want them to have a little wider stance if i'm honest, rather than going for standard spacing. Just so they fill the arch better, not so much that they stick out.
    Dec 2009
    Chichester
    217
    That's based on 8P offset though... Do you know those wheels are 45-50?
    I'd imagine the adapters are likely to be at least 25mm, so you'd have a bit more poke than standard. That's if they are 8P offset...
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by Curt View Post
    Yeah, the wheels are from an A3 8P with 45-50.
    The adapters from DPM are either 20, 25 or 30mm spacing. Unsure which to go for....probably go for 20mm at a guess.
    Sandip fitted the 19's to his and used 20mm on the front and 25mm on the rear:
    Classifieds: 19 " BBS RS861's + adaptors + tyres
    Would mine use the same spacers even if the rim is smaller?
    Dec 2009
    Chichester
    217
    Well it'd help to know which it is...
    But if you're basing it on 45mm, with 20mm adapters you're looking at ET25. Which shouldn't be a problem.
    Stick the details in this and see what you think:
    Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    This is what i think the calculations are:
    A3 8P - New wheels
    S3 8L - Old wheels
    Dec 2009
    Chichester
    217
    It won't be ET50 though... it'll be 25-30
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Is that because the spacers will be minused from the original offset stated for standard car? Sorry - i'm a total noob to wheel dimensions and don't understand the calculations ha.
    Dec 2009
    Chichester
    217
    Yeah, that's correct. Obviously your spacers will push the wheels out by another 20mm (if they're the ones you go for...) so you have to take that into account.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    I see, let me try again....
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    This is based on 50 offset with 20mm spacers.
    Dec 2009
    Chichester
    217
    Yep, that's right. Hardly any difference then. But bear in mind that you may have 5mm more poke if they're 45 offset. Unless you know they're 50?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Minus your spacer from your offset. Would help if you knew the offset of the wheels youre thinking of. Then you can get it bang on then. For instance if you wanted them say 5mm further than your current wheels, youd subtract from the ET in the calculator till you achieve it, and bingo, you know what size spacers to give you that offset.
    The 'poke' will vary with rim width bte, but not diameter. So an et30 7 inch rim would look completely different to an et30 8 inch rim.
    8p wheels tend to have a high offset, so for now assume the least for your calculations, then you will never be too much, and hitting your arches.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Ok guys, so please bare with me.
    I roughly know the offset of the new wheels based on info from wheel dimension sites.
    How am i going to find out the wheel's true accurate offset?
    Dec 2009
    Chichester
    217
    Ask the seller what is stamped into the wheel (presuming that you haven't already got them...).
    But either way, 20mm adapters will be fine.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Not got them yet. Didn't know there were more stamps on the wheel, i thought that what i put up was the only dimensions stamped into the wheels.
    Dec 2009
    Chichester
    217
    Nah, should have everything you need on there
  28. #27
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    The offset and pcd are also stamped. Id also bet that 20mm will suffice. 25 at a push providing the new wheels are high like et48
  29. #28
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    I will keep you both updated once i have the answers for you.
    Thanks alot to everyone contributing to this thread and helping a noob out!
    Shaun.
  30. #29
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Not a problem. Its funny me and curt postong the same thing at the same time and replying to us both lol.
  31. #30
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Didn't want either of you to feel left out ha
  32. #31
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Right - I have the answers as promised
    5x112
    57.1
    7.5J
    ET54
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Wow, very high, big ass adapters needed then. Plug your numbers in
  34. #33
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Forget it and buy a set of 8's in a decent offset I say.
    You'll be spending as much on adapters/spacers as you will on another set of wheels.
    I quite often say I'm going to do things.
    Then never do them.
  35. #34
    Dec 2009
    Chichester
    217
    Due to the fact that they're more narrow than your current wheels, I think 25mm would be a better bet. That's high
  36. #35
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Ooh from the pic of the back of the spokes they look like BBS speed lines like I fitted to mine?
    ShaunS3 likes this.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  37. #36
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Quote Originally Posted by vfr800 View Post
    Yups
  38. #37
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Quote Originally Posted by 16Klappe View Post
    I'm in agreement with this really. Can you not buy these rims in the correct offset and stud pattern for the 8L? I can understand if the rims are rare or unique of course. But to add all that extra unstrung weight, just to fit a set of rims is stupid in my opinion.
  39. #38
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,100
    Sound advice this.
    I only run 5 x 112 fitment with adapters because of how cheap I picked by BBS rims up for in the first place.
    By the time you factor in set of decent adapters and bolts it can/will get very costly.
    Btw just a note; if you do go for the H&R adapters then your OEM wheel brace tool in the spare wheel well will be useless if you get a flat tyre, as it's too bloody fat to get between the edge of the hole and the nut
    2000 S3 APY
  40. #39
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    But they look so good!
    Quote Originally Posted by kwistof View Post
    Sound advice this.
    I never thought about the spare wheel - ooops. Will keep a socket and breaker bar in the car from now on.
  41. #40
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    823
    Can you give me the dimensions of yours buddy?
  1. Will these wheels fit?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2007, 21:11
  2. Will these wheels fit..... Please help.
    By Jaffa in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2006, 22:30
  3. will these wheels fit my 2.8 v6
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2006, 22:16
  4. Will these wheels fit my A3?
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2005, 18:47
  5. Will these wheels fit my 1998 A4 1.8 SE ???
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2004, 14:38
