Results 1 to 7 of 7
    Jul 2013
    21
    S3 Cam Belt Snapped
    Hi all,
    Im new to this and posted in the wrong bit so here goes.
    Must firstly say I'm new to posting but I've always looked on the forum and found what I needed, U lot are brill.
    Right now for the bad bit, my cam belts gone, I've pulled the head off and as per its done the exhaust valves, there is slight marking on the pistons, do you think I'll just get away with the head work?
    please hellllphellllp
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    As long as it didn't bend any rods then you should be fine with just a new head, but while you're there you may as well put some forged rods in.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Jul 2013
    21
    Is there anyway of checking for bent rods?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    Smoith the contact marks on pistons, new valves, jobs a gudden
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    P.s. If you need some valves, holla
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by MarcS3 View Post
    Removing them or turning the engine over with the head off and if one is slightly bent, the piston won't reach the top of the bore (TDC).
    PS3: Broady_11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    With the head off it should be obvious... rotate the crank to TDC and check to see if one piston sits lower than the other... rotate the crank 180 degrees to bring the other two pistons up and check them...
    Typically when a rod goes it will either bend slightly so the piston is lower than the deck at the top of its stroke or exit through the side of the block... if the rod is badly bent then it will have taken out an oil squirter and possibly a chunk out of the bottom of the bore...
    <tuffty/>
  1. Cam Belt Snapped on 2002 S3
    By MarcS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2013, 17:12
  2. Cam belt snapped
    By Joelboy in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd March 2012, 22:08
  3. Disaster! A3 Cam belt failed but not snapped
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2007, 09:25
  4. Cam belt snapped S3 - Advise requested
    By GeoffW in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2007, 17:39
  5. Cam belt snap...
    By imported_GTiwale in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th January 2006, 14:14
