milltek exhaust
S3_DAVE
Hi All,
Just wanted to ask and get peoples feedback/preference/opinions
I am looking to get a Milltek turbo back, sports cat, non res from AMD essex when i get my stage 1 remap on my 2001 Audi S3 AMK engine. But I'm just wondering what the droning is going to be like?
Anyone got any clips of how the sounds vary? I have had a look on youtube and most seem to be decatted...
any help would be appreciated
Dave :)
The only time I notice a drone is at 3k revs onthe motorway in 6th gear but that's more down to the exhaust manifold and downpipe then the non res miltek and decat.
Reactions: S3_DAVE
Unless things have improved with them over the past 5-6 years then they are badly fitting & don't give any performance gain.
I went back to the standard one after several attempts to sort it out. Banging & clattering off the underside etc.
If you do a search, you'll find plenty of posts on here with the same issues & poor customer support...
No drone btw.
Don't get me wrong, they were proven on the early S4's for sound & gains, & I wouldn't see past them for that particular car, but they just don't do anything for the S3.
They may help performance if you are going down the bigger turbo route & taking things further, but on a stage 1 its not worth it in my eyes.
I've never had an issue with fitment. I fitted mine myself and it went on first time with no issues. The additional diameter in pipework and lack of OEM resonator will give performance gains. There will be less back pressure and also EGTs witty be lower as exhaust gases can escape quicker.
Yeah fitted mine with no issues. I would say little to no performance gain. In fact the car felt as if it had lost a bit. For the amount of money it will cost there are better mods out there that will give you a better bang for your buck eg B5 tip
Oh yeah this is a bottom I the list mod and was infact my last hardware mod just to get te best from my K04 and crack the 300bhp barrier.
Sorry, by badly fitting, I never meant having difficulty fitting it to the car.
It was more of the larger dia tubing having less clearance & therefore hitting on various places when going over bumps etc.
You found no issues with this?
Maybe I just had a bad one. Fri noon or Monday morning build lol!
I have had clearance issues on speed bumps but it's only the fixing bracket at the decat an my car is only lowered 30mm which is nothing in this day and age. I used to own a Renault 5 GT turbo many years ago an that was inches from the ground so I guess I'm used to it ;)
To the o.p by far the best 2 mods with most noticeable gains have been a B5 tip and Relentless V2 mani. Those along with a remap is what I would do first if I were to do it all again, although quality control with the manifolds are something else.
I wish Bill @ B5 would develop his.
I know its not an audi but me and my mate fitted a full ss turbo back miltek exhaust system to his misses leon cupra which she bought at gti international from there stand. At first i was a bit concerned when they came back and said they had bought a new system from the miltek, ££££ however the guy did them a good price with discount for purchasing at gti. It turned up within one day of cleared payment and i must say it fitted perfectly, we didnt have to modify anything, simply bolt on. Everything lined up a treat. probably one of the best out of the box bolt on exhausts iv handled. Sounds quiet on tick over and subtle during low revs however when u plant you foot it sounds brilliant, a lot like my custom long-life system. I simply didnt by a miltek due to the price tag when compared to a custom fabricated exhaust.
Reactions: S3_DAVE
Buying and fitting a larger exhaust system and expecting the same clearance is a bit stupid, especially if you happen to have a lowered car.
I wasnt a miltek fan, purely because of price and tge fact its not a huge 'performance mod' in terms of gains.
But, i got one very cheap, and brand new, when i fitted it (with a 3 inch downpipe and decat) i couldnt believe how quiet it was, i was underwhelmed at first. Then having had a mate take the car for a blast with me outside to listen, you realise how well made they are, and the little noise inside is totally contrasting to the noise they make outside. It is an impressive piece of hardware from that perspective.
As for performance gains, its virtually none existent on 'generic' tuned cars, start taking the ko4 to the limit and 300+hp tho and it will probably help with flow but most importantly egts. This was realised on tufftys car in the early days of his BT build when noticing egts getting very high when pushing his turbo, the miltek fixed the egt issue and allowed him to net more Hp. Granted he did have a 3 inch centre section made as opposed to the milteks 2.75, but still, prinicples remain the same and the restrictions were highlighted clearly.
The limits i dont think are very known, although i think andrew is using one on his 500+hp car and wants to get rid. I think logically if the stock system is getting choaked at circa 350hp levels, and an increase in diameter of 10% fixes that, then maybe approaching 400hp is the limit for a 2.75inch miltek.
A big box like a miltek also wont be a fan of boost build launch and no lift shift. Which is why i might get rid of mine.
Reactions: S3_DAVE
I have the full Milltek non res on my A3. There are slight droning between 1800-2000 RPM, if you keep it there. When it crosses over it sounds dreadful actually. Other than that, there is no droning to speak of. Gurgles alot, reminds me of the sounds VR6's make. Would recommend.
I have a few young mates (18-20) that are quite boyracerish, and according to them it could be louder. So that gives you an idea, that its not overly loud. Definetly too loud for your mum, but not too loud for any guy into cars. I have heard the non res, and quite honestly it sounded almost completely like the OEM.
Also, i had an issue with the exhaust knocking on the rear axel when i had people sitting in the back. Had to get a shop to modify that a little.
I had it dynoed before and after, and according to that dyno atleast, i went from 207 to 223 without a remap, but i guess you cant ever trust the dyno lotterey.
Reactions: S3_DAVE
At the moment I have a Jetex cone filter with a badger 5 TIP and heat shield, forge 008 DV.
The badger5 TIP definitely makes a massive difference.
Ok so a good start then. Honestly I would not buy the exhaust as you will see no gain from it. I started off with the same parts you have and next was a revo stage 1. That really brought a smile to my face and then I bought a new downpipe and miltek system and to be honest the car felt as if it lost power.
My suggestion would be to get it mapped as it is now. Will cost the same as the exhaust but will be way more fun.
Reactions: Revo Steve-W
No drone btw.
This^^^ is the total opposite to my experiences with Miltek.
My Miltek has done over 120k across two cars, had the tail pipes cut off and re-welded, had a 150mph smash at the ring and been bent in half by the rear beam then pulled straight. Fair to say that in its life it has been abused.
However is still sounds incredible, is very quiet at idle and sounds subtle and bassy on full chat with a slight raspy note which is very tasteful.
It doesn't make an offensive noise, it makes a pleasant burble. No droning with a non-res for my A3, so I would assume the same for an S3.
The restriction on the stock cat back is mostly after stage 2, so in terms of performance it is mainly a placebo effect for most owners.
When I required a new axle pipe after 5 years of fitment I phoned Miltek and they put me through to Awesome, who gave me a small discount and provided all necessary clamps from Miltek which were of great quality.
IMO the best "off the shelf" exhaust available, I have seen heard Milteks fitted to many VAGs, BMWs and Minis and they have all looked great and made a beautiful sound.
The quality and thoughtful design is so good, especially on Mk5 ones where they keep the exhaust tips adjustable for a perfect fitment. I really liked that.
[video]http://m.youtube.com/?reload=2&rdm=04hw#/watch?v=EUXosxUGpDs[/video]
Reactions: S3_DAVE
Undeniable difference.
10bhp+ and bundles of extra torque. Flow = POWER.
Yes it does, in both sound and performance. Even going from an APR tip to the B5 was noticeable. I run the old skool v1 too.
Don't know about the exhaust as I would not change mine but the Badger5 TIP does make a difference yeh, mine felt a lot better between 4 and 6k.
Do the badger5 tip really make that much of a difference?
You should defiantly do it... I didn’t think it would be that noticeable but once you see how small and restrictive the standard pipe is you will understand why.
I brought the B5 V3 pipe as it was one complete unit and screws onto the turbo inlet easy install plus there are a few guides on here which will walk you through it. People have also said good things about the V1 and V2 versions I just though the complete one piece would be easy to work with :).
Build quality is second to none but it is from Bill Badger5 so you wouldn’t get anything less :)
I've got a 3" relentless DP and CAT, badger 5 custom 3" cat back with milltek back box and mines quiet!
Like I said, they were one of the best money could by for the S4, just my one was no good for the S3...
There's no disputing the note from them either! Sounded sweet!
Reactions: 16Klappe
i got a miltek catback on my a3 very cheap material low grade stainless not mandrel bent no performance gains as such doesent fit great along car either coming off for a custom system soon only got it as i got it cheap id avoid a mitek on any car i ever own think of mitek like religion just because alot of people believe in something doesnt make it right
It's a bit difficult to compare an off the Shelf miltek with a custom exhaust. Obviously a custom exhaust can be made from what you want, fit how you want it, and bend how you want it. It will also cost a lot more money too.
custom exhausts are not really that much more expensive than a miltek i would understand if miltek were cheap but there not a 2.5" catback system for a golf a3 etc would range from 300-450 in most exhasust shops milteks are 400 ish i believe its just not feasable to me to buy one new
for £500 a cat back on S3 could be made at a number of places in 3"
My local exhaust shop makes up custom exhausts (powerspeed) and are definitely cheaper than a Milltek. Yes they do have the machine on site to bend the piping also.
They want around £350-£400 depending on the TIPs you want and if you want a silencer plus the back box after the cat. Last time I checked it was around £530 inc fitting for a Milltek.
I will still be opting for the Milltek though (because I'm such a brand whore :p lol)
I know where theres a brand new milltek back box and used resonated center pipe for a good price ;)
Oh the badger5 tip is only for k04 and up, wont fit my A3, not to mention it says it only fits right hand drive models, wtf, why would that matter.
14
2K
935
21
814
6
