Monster MotorsportChris Nott
Results 1 to 8 of 8
    Oct 2012
    122
    which lowering spring that dont lower!
    guys
    im in need of a new set of springs and looking at the service history/receipts the front left is the only original and the rest are mismatched autofactor tat.
    iv always been in the school of thinking that wishbones need to be flat for best handling, bump steer etc. so as they are almost that now, im looking for springs that dont actually lower the car.
    the ones i have found are-
    H&R Lowering Springs Kit For Volkswagen Golf Mk4 GTI 1998 1.8 Turbo 29527-1 | eBay
    Eibach Pro Kit Lowering Springs Kit For Volkswagen Golf Mk4 GTI 2002 1.8 Turbo | eBay
    now, does anyone have experiance of any of the above springs?
    Im looking for comfort with a sporty edge. will be replacing dampers with bilstein b4 OE items.
    also, they both quote lowering of 30mm. is that from the standard golf height (ie none GTI)?
    And as already said, its a golf! 1.8t. i just find this the best forum for the 1.8t.
    kind regards
    Paul
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Go for the Eibachs Paul, and stick both the original and the Eibach spring pads on the rear.
    Here's a thread I did previously for some feed back.
    http://www.audi-sport.net/vb/a3-s3-f...g-springs.html
    You've got to have a laugh!
    Mar 2013
    Devon
    398
    Can highly recommend the Eibach Pro Kit. Comfort is not as good as stock, but not far off.
    Most comfortable aftermarket springs I have tried. I run them on my daily golf diesel too and never get complaints from the family!
    Oct 2012
    122
    thank you chaps. JoJo. I have heard problems with the eibachs being too low at the back. is this because people take the OE spring plate out?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by paultownsend View Post
    I'm not really sure Paul, I found the Eibachs to be really comfortable, on par with OEM, but I wanted my car lower, so refered the setup as the front being so high, and I ran them with the OE spring plate out, as they come with a spring pate anyways. But there's another member who has the OE spring plate and the Eibachs one fitted, to elevate the rear, and the ride height looks spot on, albeit, not as low as I prefer it, but it looked balanced.
    Mar 2013
    Devon
    398
    I was unsure of this when my Eibach kit arrived, there was no info in the box.
    I managed to get a phone number for Eibach and was told told both the OEM bottom mount and the OEM top spring mount should be kept. The rubber mount pad that comes in the box is in addition and goes on the top of the spring above the OEM mount, so it is touching the car body on the fattest bit of the cone that holds the spring in place.
    The ride height looks spot on to me.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As above, I'd stick with the Eibachs.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Jul 2011
    49
    Add S3_DAVE on Facebook Visit S3_DAVE's Instagram Channel
    defo a +1 on the Eibachs there more sporty feeling but not far from comfort of OEM
    As said above leave the rear spring plate and you should also get some in the kit- remember to use both and it will sit perfectly
    I chose this time to replace my top mounts on the front with LCR as there a bit more stiff over OEM also as my top mounts were worn.
  1. lowering springs fitting - which way?
    By 205man in forum General Automotive Chat
    Last Post: 15th October 2010, 20:05
  2. fitting rear lowering springs (which way up)
    By afcjay in forum Handling
    Last Post: 29th July 2010, 00:05
  3. A4 B6 , Eibach lowering springs, do they lower 30mm ?????
    By Digger1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2010, 20:53
  4. which lowering springs?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2009, 21:01
  5. Which lowering springs for 2000 S3?
    By ScottandJo in forum Tuning
    Last Post: 14th November 2008, 12:45
