JMB RetrofitsAH Fabrications
Thread: SUNROOF woes
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    220
    SUNROOF woes
    the sunroof has decided its not happy obeying the instructions of the rotor switch....
    IF you want to tilt it open... it doesnt move
    IF you want to retract it I need to pull the lever down as if closing it from the tilt open position, there after to open it further back I twist the rotor switch as normal in its increments until fully retracted
    IF you want to close it from the fully retracted position I twist the switch which brings it to about 4 inches from being closed, then I need to pull the switch down for it to fully close
    local Audi master techy chappy who looks after our cars says its not a straight 5 min fix and the headingling might have to be dropped !!!
    anyone else had / got a disobedient sunroof and whats the problemo ? I assumed the internal workings has jumped a tooth but apparently not
    suggestions please peeps
    Rich
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,275
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I've had this happen a couple of times now....
    Pretty sure it's due to the control module thinking the sunroof is in a different position to where the sunroof actually is; mine was even trying to open itself more than it should and this was all around winter time! Once it realised it couldn't open anymore- it would then default back to being half open!
    I ended up curing my sunroof by literally playing with the controls in the car and on the key fob none stop for an hour or so....I think there is a way to re-set the alignment fully, but I managed to get mine sorted myself with a lot of patience.
    I think it may occur due to turning the car of/on and having the sunroof set in a position other than fully open/tilted/closed....then if you change the position of the dial inside whilst the car sunroof cannot be operated it may not pick this up at the time. Usually the sunroof sorts itself out when the ignition is turned on- but sometimes it's a bit slow on the uptake and presumes the mid position of the sunroof is either open/closed/tilted. Hence why playing with the dial and key fob has always sorted my issue out for me.
    Good luck
    Chris
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    quattrokid's Avatar
    Jan 2006
    220
    hello again !!
    ok,i'll have a fiddle as you suggest..... by the way, it was the longitude acceleration sensor that was causing the abs & traction control light to come on the dash intermittantly but not leaving any fault codes, changed abs pump/ esp module which immediately pointed its finger to this sensor, changed the sensor and so far its been ok....
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,275
    Quote Originally Posted by quattrokid View Post
    hello again !!
    Haha- hello again
    I thought I recognised the username. Glad you got the ABS sorted- that warning light does get pretty tiresome after a while!
    Seems as though the electrics in your car like being intermittent and causing you issues though:-\ There getting pretty old now - and seem to have a mind of there own, but your not alone! lol
    Hopefully having a little play will sort it all out- just don't try and start forcing it with your hands or tools and give it some time/patience.
    2000 S3 APY
  1. Front Suspension Woes (a wee bit longish)
    By IanWood in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2004, 14:04
  2. Squeks and Green stuff on the sunroof???
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 13:34
  3. Anyone got a new model A3 with a sunroof?
    By Irish in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2004, 04:55
  4. 80 quattro insurance woes
    By leebex in forum Classic Audi Forum
    Last Post: 18th April 2004, 18:42
  5. Browser woes
    By AlexStanley in forum General Chat
    Last Post: 9th May 2003, 15:51
