EM TuningJMB Retrofits
Results 1 to 14 of 14
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Need a new gearbox
    Hi guys, I was wondering if I can fit a gearbox from a aum engined car onto my agu? Is there any differences between the two box? Like different fittings etc?
    thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Jun 2012
    Redhill Surrey
    635
    Bump
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    It's essentially the same mate, but depending on the year of your agu a few bits may need swapping over.
    Early agu boxes will have an 02A style shift tower and 100mm drive flanges, where later ones will have a true 02J shift tower and 108mm flanges same as AUM.
    worst case you can swap these bits back onto the aum box if needs be, or modernise your car a touch by adding the further parts required to use the better aum shift tower.
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Not A good way to start a thread dude whats up eith your gearbox mate ?
    Jun 2012
    Redhill Surrey
    635
    Ok cheers prawn, mine is a 98 r reg so take it that it will be an early agu.
    Grant, been told that the diff is knackered and bearings are gone and that's causing the left hand pull.
    Jun 2012
    Redhill Surrey
    635
    Anyone else get a noise like ping pong balls rattling in the gearbox? As soon as I press the clutch pedal down it goes away?
    Jun 2012
    Redhill Surrey
    635
    Guys am I right in thinking the gearbox code for my car can be found on the sticker in the spare wheel holder too the right of the engine code?
    I have the letters DBZ would this be my gearbox code as I need to replace my gearbox?
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    Yeah its on the sticker
    DBZ gearbox in Car Parts | eBay
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Jun 2012
    Redhill Surrey
    635
    Great thought I'd double check that was the case,
    Jun 2012
    Redhill Surrey
    635
    Guys my gearbox code is DBZ would a ENJ fit straight on or would I need to change anything? If I bought it, it would be coming off another agu.
    thanks simon
    dusty's Avatar
    Nov 2010
    nw england
    144
    Are you sure it's the gearbox I'm no expert but sounds more like dmf or clutch if the noise stops when you press the clutch pedal down
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    Jun 2012
    Redhill Surrey
    635
    The noise I can hear isn't why I need a new gearbox, and I don't have a dmf I had a smf and new clutch fitted in march,
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    886
    Add Vex182 on Facebook
    Quote Originally Posted by Grale1 View Post
    Is it not the "chatter" from the smf flywheel conversion?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2012
    Redhill Surrey
    635
    Can someone clear up so info for me as I've read a few different things now, on my car I have DBZ gearbox code, and I've bought a ENJ code box, now I've read that they both have the same flange size of 108mm, is this right? As I've also read that my DBZ has 100mm flanges?
  1. Please help :( a3 dsg gearbox, need a new 1
    By Chady in forum Volkswagen and other VAG
    Last Post: 10th July 2012, 13:09
  2. New gearbox needed
    By Jurassic Pork in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2011, 22:42
  3. Big favour needed from New A3 owner (with armrest)
    By garethj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2005, 12:17
  4. Audi 100 E Avant Auto - new gearbox
    By badger81mini in forum General Technical / How To
    Last Post: 15th August 2004, 17:45
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
