Badger5EM Tuning
Thread: Air con problem
    Sep 2010
    498
    Air con problem
    I have a 52 reg A3. It has the digital climate control. However, what with this warm weather there is a bit of an issue! The air con on the coldest setting is blowing out luke warm air. The gas is filled up, fuses fine. Last summer it worked a treat. Anyone had a similar issue?
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    check compressor clutch?, friend of mine has similar issue with A4, have you run vcds to check for any faults?
    Sep 2010
    498
    Not checked any codes yet. How do I check the compressor clutch? The engine not does change slightly when changing from air con to econ.
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    The engine should load up, i.e your should hear a deffinite click as the compressor kicks in and this is sometimes accompained with a change in revs the A/C fan may also cut in as well, depends on the system demand, I hate to say it but I believe halfords do a free check on the A/C system and if they cannot fix it there is no charge, but check this out before letting them look at it, hope this helps out?
    Carl
    Jun 2013
    16
    Exactly the same problem my friend. I work with a lot of brand new cars which really highlights the difference in performance of air conditioning between my 14 year old A3 and those. I get warm air at best from mine - absolutely killer in this weather
  1. Air Con Problems
    By WAL4D in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 21:39
  2. Air Con Problem: Slothlike coldness
    By hyperaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2006, 08:44
  3. Air Con Problem
    By Quattro_Lew in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2006, 21:54
  4. Air Con Problems A3 1.8 T Sport
    By jester104 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2006, 14:15
  5. Air Con-Problem
    By Jason in forum General Technical / How To
    Last Post: 22nd May 2006, 13:41
