Monster MotorsportEM Tuning
    Oct 2009
    16
    S3 exhaust gas temp sensor problem
    Hi I have a 2001 audi s3 amk engine and I have had a problem with it feeling sluggish I have sorted some boost leaks and I forgot to plug in the exhaust gas temp sensor went for a drive and it felt great plugged vag com on to the car found egt to bee open circuit so plugged it back in went for a drive and it felt sluggish again any surgestions on what the problem could be
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    Doesn't the egt stores an error when its plugged and you scan the car with vag com
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    With the EGT probe disconnected the ecu runs in protection tables (ecu sees a temp of 1100 degrees) and will over fuel (0.75 lambda) all the time... you will get rubbish MPG and bore wash which promotes engine wear..
    I think the 'sluggishness' could be something else tbh... clear all fault codes and see what comes back... allow the ECU to adapt properly (will take a few miles of driving) and this should bring things back in check...
    Failing that logging will be needed to see if there is any other issues
    <tuffty/>
  1. ECU Error: 17861 - Exhaust Gas Temp Sensor 1
    By smoking_bob in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2012, 12:23
  2. Exhaust Gas Temp Sensor
    By Dougster67 in forum General Technical / How To
    Last Post: 17th September 2011, 17:06
  3. Exhaust gas temp sensor
    By gez in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2010, 17:48
  4. intake air temp. sensor problems
    By routers77 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2010, 12:48
  5. Continuous Engine Coolant Temp. Sensor Problem - PLEASE HELP!
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2009, 15:25
