Volks AutosSky Insurance
Results 1 to 18 of 18
Thread: FPR Question...
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    FPR Question...
    Right, are the FPR's in the 1.8T Variable? i.e, do they supply 4 bar or >4 bar?, likewise is the 3bar FPR >3bar.
    Pretty certain they are variable i.e supply on demand.
    Rich
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: FPR Question...
    4 bar if the vacuum hose is not connected...
    Less than 4 bar at idle, with that line under vacuum, to reduce the fuel pressure further and assist idle emissions....pretty much 4 bar everywhere else except under full vacuum (idle, with a closed throttle butterfly).
    Same principle with the 3 bar versions...
    I verified this the hard way...try setting up a standalone ECU with the vacuum line connected! The fuel pressure is all over the place at idle...not good for setting baseline idle maps up.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    Cool.. Thanks Glen.
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    Re: FPR Question...
    Rich, there is a bosch 5 bar fpr available that will give linear fuel curve for mapping, have yet to find where to get them though, try bosch motorsport.
    also some peope use crushed fpr's, like 4 bar on s3, s4 to give 5 bar, only problem is it will give non-linear fuel curve, is PITA for tuners on RR
    what has actually happened here is the fpr spring has been crushed and is constantly more compressed giving the higher pressure but at the same time gives it less movement under compression so non-linear fueling , this is the principle of the adjustable fpr's that are 3-5 bar etc,
    hope thats helpful
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    My query is concerning emissions... I need to cut mine down a little for the MOT... CO2 is too high, which means its running too rich...
    Rich
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    Re: FPR Question...
    oh my appologies. thats what happens when i skim read.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    No worries dude... I didnt mention why in my first post anyway! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Feb 2004
    UK
    1,320
    Re: FPR Question...
    I'm using a 3.5bar fpr or thats what jabba said and it sailed through the emissions.
    Maybe your mapping is at fault?AMD isn't it.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: FPR Question...
    Hi Ryan,
    is that a not so subtle moan about AmD, are you speaking from experience?
    Just interested to know...
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    No fault with the map thanks. Had a major air leak last year which wont have helped. I've checked AFR numerous times and its perfect.
    Feb 2004
    UK
    1,320
    Re: FPR Question...
    Don't know anything about AMD mapping,i know gary handas car melted after a rr session there whos fault i have no idea..
    In my opinion Mike at Jabbasport is the best 1.8t mapper in the uk.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    But Gary Handas is not the only one... There have been numerous cars that have melted housings...Bill's ibiza being one of them.
    Feb 2004
    UK
    1,320
    Re: FPR Question...
    Gary Handa melted a piston ring on the dyno being tuned on the RR at AMD and need a complete rebuild
    Bill melted a housing on the track after 45k of track miles,engine was not harmed.
    big difference.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    Not going to get into this arguement again...Its getting dull.
    My question was answered.
    Feb 2004
    UK
    1,320
    Re: FPR Question...
    Didn't relise there was/is a argument.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    There isnt.. But i dont want to get into one, because thats the way it always ends up...
    Feb 2004
    UK
    1,320
    Re: FPR Question...
    No worries.end of discussion
    ...Watching you!
    Earlsfield, London
    5,087
    Re: FPR Question...
    Had MOT done today...passed no problem! emissions are perfect .etc, so last years prob was vacuum leak messing up the mixture!
    Rich
