EM TuningBadger5
    Nov 2007
    49
    Perished hose on intake manifold / boost leak
    I'm 99% I've got a boost leak - I can hear the turbo spinning quite loudly but it's not translating into much extra power!
    I've rummaged around and the only perished hose I can find is the one on the top right of the intake manifold which I can't really figure out what it's doing - it runs off a few places out of sight! Any ideas what it does and if it would be having an impact?
    I've scanned for faults and the only one that comes up is:
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-10 - - - Intermittent
    I've seen another thread (which I now can't find) which suggested this could be due to the N112, however I've not been able to check that yet - helpfully the screws holding the plastic trim onto the plate it's mounted under have been rounded off so I'll be drilling them out at the weekend!
    Any other suggestions?
    RIP S3dave
    May 2004
    nr Glos
    7,167
    get it smoke tested to confirm ALL the leaks... and replace the hoses
    inlet manifold to PCV T-piece is likely culprit but probably not the only one
    look for pipes under the intake manifold which are covered in oil. ask yourself how this oil got Outside of the pipe? There will be a leak close by
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2007
    49
    Will do - any recommendations for somewhere that can smoke test around Guildford - there's a serious lack of decent VAG specialists around here!
    The hose in question is crimped into a metal pipe to go over the engine then converts back to rubber - presumably an expensive dealer part so is there any reason I can't replace with a single piece of silicone hose (teed as necessary - I forget the routing).
    May 2013
    Glasgow, Scotland
    195
    Hey is it this 1:
  1. Boost leak from Inlet manifold injector inserts, advice needed
    By S3 ROCKS in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2013, 17:39
  2. Oil filter housing breather hose question-BOOST LEAK?
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2012, 19:52
  3. Perished hose connecting to inlet manifold
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 23:12
  4. Manifold Boost Pressure Switch
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2004, 20:30
  5. Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2004, 20:47
