EM TuningVolks Autos
    Jun 2013
    7
    Super hot Wing Mirror Problem
    Hi, I was driving along today and from out of nowhere my wing mirror fell out "just the mirror bit", luckily it held on due to its electrical wires. I stopped and went to put the said mirror back in and found it was really hot to touch???, I checked the other mirror and this was warm but nowhere near the other. I'm guessing a regulator of sorts has broken. Anyone had this happen?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    when i use mine thay do get hot
    they only work whn the rear heater is on
    Jun 2013
    7
    I have no heaters or anything on. Weird, I guess I should just disconnect the connecters for now.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    821
    Add Vex182 on Facebook
    My mirrors get hot in the winter when it's below 5c, even with the rear screen off.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    453
    Yep that's correct. They should work automatically when outside temp is less than 5 degs and regardless of whether heated screen is on or not.
    Does your temp gauge work correctly?
  1. S3 wing mirror base fitting problem!
    By Chlippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2010, 13:49
  2. window/wing mirrors problems
    By hudson89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 17:37
  3. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
  4. another alluminium wing mirror ??
    By darrenrally in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2003, 16:24
  5. Funny passenger side wing mirror.
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2003, 08:44
