Badger5Chris Nott
Results 1 to 7 of 7
    Dec 2012
    bridgend wales
    51
    Unhappy door micro switch
    hi all I has anyone on here had there door lock micro switches replaced by a garage my drivers side is playing up display saying door open when its not its getting annoying now anyway how much did you pay I have read its a fiddly job hopefully not a stealers job thanks 2002 s3
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    You dont need to get it replaced, do a search on here, myself and a number of others were able to fix it with some WD40 and a wire coat hanger.
    Dec 2012
    bridgend wales
    51
    ok thanks I will a have a search
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    door micro switch
    Quote Originally Posted by downhilldave77 View Post
    My mate had the same problem with his TT but it wasn't working at all so the car wouldn't know when the door was open and it would lock itself after 30 secs unless he put the key in the ignition.
    I took his lock a part and basically the switch button is hard plastic and it is pushed by a softer plastic on the lock mechanism which eventually wears away and doesn't press the switch. All I did was remove the switch, elongate the hole it sits in so it would press the switch then glue it in place and put it all back together. I did that probably nearly a year ago now and it's still working fine.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Dec 2012
    bridgend wales
    51
    Ok thanks for that I will see what I can do cheers
    Jul 2013
    12
    The door closure sensor is part of the door lock mechanism so if you do need to replace it you have to replace the whole lock mechanism. The fixes suggested previously do work... for a time. The time they'll work for cannot be quantified. I didn't have any success with WD-40 or GT-85. If you open the door and look into the mechanism you will just about see (a torch helps) a small 'pin'. By using a small allen key I was able to hook the pin and bring it forward slightly. If you have your ignition on when attempting this fix you will both hear the sensor actuating and the door open signal on the dashboard will extinguish. This worked for me for a while but eventually it failed again. I'm in Wigan so point in recommending where I had my lock mechanism replaced but if it helps it was an independent garage and the total cost for the new, genuine part including fitting and vat was just shy of £100.
    Nilz's Avatar
    Apr 2006
    10,087
    You will also see when youa re hitting the switch as the light at the bottom of the door will go on and off.
  1. A3 door micro switch
    By Ads_AudiA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2012, 11:10
  2. Does a mk4 golf door lock micro switch fit 8l s3???
    By Audi S3 freak in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2012, 16:38
  3. Where is door light micro switch?
    By wellhouse0 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2009, 20:02
  4. faulty drivers door catch / switch
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2006, 14:33
  5. Door sensor / switch location
    By S4_dan in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st January 2006, 20:22
