Monster MotorsportVolks Autos
Results 1 to 7 of 7
Thread: S3 Clutch
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    460
    S3 Clutch
    Hey Guys, It's been a while!
    My S3 has finally got to the point that I have to replace the clutch. The car has a stage 2 revo remap and all the bits needed for this. the garage I am having it done at is worried that a standard clutch may go again rather quickly as its not beefy enough.
    I can't quite remember if I read on here thinking that the standard clutch was good upto 300bhp and thought I would ask for clarity!
    If upgrade recommended which clutch and where to buy?
    Thanks all and hope your well!
    Dan
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Std clutch is fine as long as you aren't launching it...
    <tuffty/>
    Oct 2012
    238
    Sorry to hijack the thread but do the bevel box seals need replacing when doing the clutch/flywheel?
    Dansmith's Avatar
    Apr 2009
    460
    <tuffty/>
    Launching uses too much petrol So standard clutch it is! You still in the Beast Tuffty?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by Rice View Post
    Its advisable when removing the bevel box as part of dropping the box... while its possible to get the box out with it attached it is far less hassle to remove it first as it gets caught on the block... 02M boxes are heavy
    Don't forget you will need a special long allen key to undo the flange retaining bolt... just undoing the four large bolts won't separate the bevel box...
    Quote Originally Posted by Dansmith View Post
    Of course
    <tuffty/>
    Dansmith's Avatar
    Apr 2009
    460
    Of course
    <tuffty/>
    I will have to look through your build thread and see what you have been upto...
    I'm guessing flywheel is recommended to be changed at the same time as the clutch? I have ordered one just incase that can be sent back if I don't use it!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Normally yeah... they 'say' its good for two clutches (typically original plus one change) before needing swapping but most I have seen are pretty fecked...
    <tuffty/>
  1. New clutch sorted and cheap !
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2003, 11:31
  2. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
  3. Clutch Dilemmas
    By RAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2003, 21:47
  4. Has anyone fitted MTM clutch?
    By theodore_p in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2003, 12:12
  5. Lifetime of an S3 Clutch - 18months / 12K miles??
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2003, 09:25
