Monster MotorsportChris Nott
Results 1 to 10 of 10
    Apr 2012
    62
    First service: what do I need?
    Hi,
    I'm doing the first service on the car I just got, my first service, not the cars obviously.
    It's done 38k. Was gonna send it to audi to do but as they're trying to fob me off with the corrosion job they can go to hell.
    The car is an A3 1.8SE 2001.
    I haven't a manual, so my questions are.
    1. Which spark plugs do I need? (Gap?)
    2. Is semi-synth okay, I'm doing yearly services anyway.
    3. Is the petrol filter that cylinder under car next to tank?
    4. Is there a pollen filter in my car? If so, where is access?
    5. Is there a manual to download anywhere?
    Also, my car is logging coolant sensor fault. It disappeared for about 4 weeks then returned. I've noticed today gauge went to 90 pretty quick, then dropped back to 1/4 way round then back to 90, so not sure whether its faulty or bad connection.
    Sorry for all the questions guys.
    Much appreciated any help.
    Danny
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Hi,
    1. Which spark plugs do I need? (Gap?) Think its 0.7 but good to check
    2. Is semi-synth okay, I'm doing yearly services anyway. full synthetic, quatum 5w40 is what you should use. id service it more often than once a year if I were you though....
    3. Is the petrol filter that cylinder under car next to tank?yes thats the one. worth changing if its never been done. the clips can snap so be careful
    4. Is there a pollen filter in my car? If so, where is access?Its under the scuttle pannel on the passenger side
    May be worth changing your coolant temp sensor on the right side of the engine and the thermostat too
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Semi-synth is fine.
    Petrol filter is the cylinder under the car, yes.
    Manual here, which has the pollen filter removal/replacement guide included.
    Audi A3/S3 Workshop Manuals
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Apr 2012
    62
    Hi Thanks,
    Semi-Syn once a year!! I do only do around 6k a year.
    russwuss's Avatar
    Feb 2013
    437
    I used this oil first time I serviced the S3
    Fuchs TITAN SUPERSYN 5W-40 High Performance, Fully Synthetic, Engine Oil
    use WEEKLYDEAL voucher code and it's £17.99 ;-)
    Apr 2012
    62
    Quote Originally Posted by russwuss View Post
    Hi,
    Yeah I saw that in an email yesterday, think I'll get some.
    WHat about spark plugs> most sites are saying NGK BKUR6ET-10 (2397) are they right?
    russwuss's Avatar
    Feb 2013
    437
    Quote Originally Posted by danfloun View Post
    Hi,
    following advice on the forum I swapped to BKR7E plugs.
    Less than £8 for 4 delivered, just replace um every 10k - working fine for me, Stage 1 260bhp.
    Link to the item I purchased.. NGK Spark Plug Standard Kit BKR7E x4 | eBay
    Apr 2012
    62
    Aren't they only recommended for chipped cars? Mines stock bland 1.8
    russwuss's Avatar
    Feb 2013
    437
    oops, sorry! For some reason I read 1.8 SE as 1.8 S3 sorry!
    I ran these with mine as stock, was remapped about 1 month later iirc.
    However this might be different for yours, I'll leave giving advice to the experts
    Apr 2012
    62
    Thanks lol.
    I'll stick with aforementioned ta.
  1. S3 90k Service - What needs doing?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2009, 21:02
  2. A3 Servicing - what parts are needed?
    By dgannon69 in forum Detailing
    Last Post: 25th August 2005, 22:29
  3. What would I need to put K04 turbo's on my car
    By abmunro in forum General Chat
    Last Post: 4th July 2004, 07:31
  4. What would I need to put K04 turbo's on my S4
    By abmunro in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2004, 22:32
  5. First Service
    By Fluff in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 19:37
