Chris NottBadger5
Results 1 to 9 of 9
    Oct 2012
    236
    Map sensor pipe inlarge S3
    Niki at r tech said it might be an idea to increase the size of the map sensor hard pipe. I'm just wondering if its worth it for stage 2... I read in another read that it wouldn't make a huge amount of difference unless it was over 300bhp, and I've worked out it'll probably cost around £90 to increase the size to 63mm from the intercooler hose to the maf as I've still got the standard hard pipe to maf hose, which is £90 is rather not spend right now. Has anyone else done this at stage 2?
    Oh and where is the best place to get standard bolt on coil packs?
    Thanks in advance
    Oct 2012
    236
    Or maybe I should stop being a tight arse.....
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,019
    Visit 16Klappe's Instagram Channel
    Bolt on coil packs hardly ever fail, however TPS is your best bet.
    I don't know many people, in fact any people who have enlarged the MAP sensor housing on a stock K04.
    I quite often say I'm going to do things.
    Then never do them.
    Oct 2012
    236
    Yeah but I've got one push on, so I need a bolt on to replace it with. Any idea how much they are?
    Ah ok mate.
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I've got all this to do mine.... I will probably have some spares...
    Oct 2012
    236
    Blimey! That's a fair bit! What are you running ?
    Jul 2010
    Teesside
    933
    Quote Originally Posted by Rice View Post
    I have a GT30..... All work in progress at the moment....
    Oct 2012
    236
    I'm not sure what that is, but it sounds more powerful than my ko4 haha. Maybe a bit overkill for mine then....
    Jul 2010
    Teesside
    933
    I would say so..... Not really needed unless you go bigger turbo.... I'm sure there are lots of other mods you could do that would be more beneficial to you..... Have a little search about previous threads and stickies..... Everything you need to know is in there fella....
  1. Custom making map sensor pipe
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2013, 22:44
  2. anyone got a spare s3 map sensor pipe
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2010, 21:56
  3. Irratic Idle - MAP sensor?
    By StanboA3 in forum Tuning
    Last Post: 31st August 2005, 20:40
  4. MAP sensor or MAF sensor
    By imported_stanA3turbo in forum Tuning
    Last Post: 17th August 2004, 23:09
