AH FabricationsVolks Autos
Results 1 to 8 of 8
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question HELP with rumbling noise....S3 experts needed!
    Recently got fitted a second hand clutch and luk dmf which had done 4K and ran fine. Sorted my slipping clutch.
    Now recently it's making a rumbling noise on idle which vibrates through the clutch pedal and is a rumbling noise when I come off the accelerator when driving. When it's on idle if I rev the car slightly it doesn't make the annoying noise!
    Took it an Audi specialist and they said its a noise coming from the transfer box and gearbox, which will cost £550 labour to remove and refit and a gearbox specialist could be anywhere from 300-900 for a rebuild.
    I would like a second opinion, could it be anything else? Like my second hand flywheel, would that make the noise. I checked the degrees of play in the flywheel and it was hardly anything! The clutch was like brand new too.
    I don't want to fork out all that money and for it to be something else, neither do I want to sell my beloved S3 after 8 years of ownership. Also I have a 3month baby and I can't bear to sell it because i won't get anything for it :-( diesel 5 door s probably the way forward but S3 are worth next to nothing now a days for such a good car!
    Cheers guys and girls in advance :-)
    Campbell
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Feb 2003
    107
    Could be the flywheel bolts... Where they changed? Or did the originals have any play in them?
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    They are originals to my knowledge and I didn't do the job so can't comment on the tightness, can this be checked from underneath? Are they the Allen headed bolts?
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    anyone??????
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    No you have to remove the subframe to drop the gearbox and inspect the flywheel, a brand new clutch, dmf flywheel and slave cylinder will cost about £900 fitted from a good specalist.
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Yea cheers, just wondered if that noise pointed to the flywheel or the gearbox from the noises it making, if anyone had any of the same noises and what it turned out to be??
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    Does the noise change on idle when you press the clutch pedal down?
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    No change in noise when pressing the clutch down on idle mate. When driving along and I come off the accelerator it rumbles and majority of the noise goes away if I either put my clutch in or coast it, which I don't do!
  1. Re: Help with any Photoshop stuff if needed
    By bhainart in forum Photography & The Digital Darkroom
    Last Post: 17th March 2010, 13:41
  2. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  3. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
