Sky InsuranceChris Nott
Results 1 to 9 of 9
    GlennP83's Avatar
    Sep 2012
    Wicklow, Ireland
    61
    Airbag fault please help
    I recently went for the Irish version of the mot and failed on an airbag fault
    00589 -airbag igniter; Passenger side (N131)
    32-10 Resistance too high - Intermittent
    This is what the vagcom said is the fault,can anyone tell me how to fix this?
    Will I need to replace the passenger side airbag?
    Any help will be greatly appreciated,thanks for looking
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    it could be as easy as cleaning the plug and pluging in
    or comon fault the plug needs cuting off and wireing up
    not the floor pulg the plug on the under side of the seat
    00589 - Airbag Igniter; Passenger Side (N131) 00589 - Airbag Igniter; Passenger Side (N131): Resistance too High
    00589 - Airbag Igniter; Passenger Side (N131): Resistance too Low
    00589 - Airbag Igniter; Passenger Side (N131): Upper Limit Exceeded
    00589 - Airbag Igniter; Passenger Side (N131): Lower Limit Exceeded
    00589 - Airbag Igniter; Driver side (N131): Short to positive
    00589 - Airbag Igniter; Driver side (N131): Short to ground
    Possible Symptoms
    • Airbag Warning Light active
    Possible Causes
    • Wiring from/to Airbag Igniter Passenger Side (N131) faulty
    • Airbag Igniter Passenger Side (N131) faulty
    Possible Solutions
    • Check Wiring from/to Airbag Igniter Passenger Side (N131)
    • Check Airbag Igniter Passenger Side (N131)
    Special Notes
    • When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
    GlennP83's Avatar
    Sep 2012
    Wicklow, Ireland
    61
    Ok ill have a look at the connections to the airbag today,Should I disconnect the battery before checking the wires?
    Ive never had airbags in a car before so please excuse the silly questions
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Common issue on all VAGs, I've never disconnected the battery personally, but it's recommended you do, just make sure there's no keys in the ignition. Unplug e connector under the seat, spray with WD40, then plug and unplug a few times. once you've done that, you need VAGCOM/VCDS to reset the airbag light, if the light doesn't go out, then there maybe a different issue.
    You've got to have a laugh!
    GlennP83's Avatar
    Sep 2012
    Wicklow, Ireland
    61
    The airbag light doesn't come on at all man,would this mean a different fault? Possibly ignitor fecked?
    bez101's Avatar
    Jul 2008
    7,911
    the bag light should be on with that code
    someone might have had the fault before you bought it and coverer the bag light
    does it come on for a few seconds when you turn the ignition on ?
    GlennP83's Avatar
    Sep 2012
    Wicklow, Ireland
    61
    No it never came on and I never noticed it tbh
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    It's between the engine and abs lights. I can email a pic to you if you want.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    This happened to mine but in 2004, the owner at that time had the airbag ecu replaced, cost him almost £500!!!
  1. Specific Electrical Faults!! Please help
    By KerryA3 in forum General Technical / How To
    Last Post: 7th February 2010, 11:32
  2. Audi 80, Immobiliser fault PLease Help...
    By kashiskash in forum Classic Audi Forum
    Last Post: 7th January 2010, 21:58
  3. Gearbox fault please help!
    By Danny Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2009, 11:10
  4. s3 fault please help?????
    By 20vtdaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2007, 00:58
  5. Electrical Faults Please help!!
    By kba3t in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2006, 21:29
