EM TuningJMB Retrofits
Results 1 to 16 of 16
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Wire 6x9 to factory amp Audi A3 8L
    Hi there. I have an Audi A3 2002 mod 8L and want to upgrade my soundsystem. I have an aftermarket headunit wich I will put in my car soon, when I get the interface I need in the mail. But I've heard that there is an amplifier in the back that amps the to speakers in the rear? Is it possible to wire 6x9 to the amp? I have the normal Audi Concert system, not the bose version.
    Gizmo20VT's Avatar
    Jun 2012
    289
    It would be possible but the rear speakers are pretty strong from factory, perhaps changed the headunit with a decent rms output on the speaker channels and see if your not satisfied?
    ALso if you change your headunit you will need a little "add-on" to get the rear setup to work again. It plugs into the OEM harness and has a remote wire and a pair of RCA's
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,528
    The subwoofer in your rear left quarter powers your rear speakers aswell. You will be better off powering the 6x9's with your replacement headunit in my opinion.
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    I have ordered a interface that will make the rear speakers work with the aftermarket headunit. Atleast that is what the soundguy told me to do.
    I'm not sure I have the subwoofer in my car though.. I don't really have a good bass sound in my car.
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    But how can I power 6x9 if I don't go through the amp? The rear speakers are in the back door panels. And I want the 6x9 on the shelf in the back..
    Gizmo20VT's Avatar
    Jun 2012
    289
    Then get the pinout for the plugged located in the rear assembly and change the wiring path from the rear door speakers to the 6x9's
    Alternative - Lay new wires from HU to 6x9's and bypass the rear "sub and speakers"
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Thanks for good help! I will go and try
    Gizmo20VT's Avatar
    Jun 2012
    289
    Plug location is by rear lights
    I used a spare on my previous 8L to make a harness for plug and play when adding my amp.
    Im just trying to locate the pinout pic in my photobucket.
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Do you know what leads to the two rear speakers? I just need to replace those two.. So I don't need to cut the whole plug off.
    Dec 2009
    Chichester
    218
    Better served throwing the 6x9s in the bin.
    If you want to upgrade the sounds system, get some decent components. Focals are a good start, even if their budget range. There is no point in putting 6x9s in and moving the sound stage to the back. The front is where you want to upgrade, the rear is just for fill.
    IMO, the best thing you can do if you want nice sound is: 4 channel amp powering front components, a sub for the bass and the rears just left to run from the head unit. If not, just uprate the front, NOT the back
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    So I change all of the component speakers, both rear and front? I have a factory sub in the side boot, but the quality is poor.. would it be a good idea to change the element in it + get a real sub on the side?
    Dec 2009
    Chichester
    218
    Just change the front speakers and tweeters, don't worry about the rear unless they're broken. In which case just get some coaxials and wire them up standard.
    Yeah the standard sub isn't much cop. Depends how much you value your boot space... If it's not much of an issue just get a 10 or 12" with suitable enclosure, or if you want to save space you can get a box which replaces your original and uses a 6" sub. Although that would be significantly more expensive.
    Then you would need an amp to power it... I'd go 4 channel so you can power the front speakers and the sub of choice
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    For a 3 door what is the best way to route wires from the hu to rears as the back speakers i cant seem to get at. I have taken door bottoms off (broken 2 metal clips) but cant seem to take back side panel off to get to the oe speakers.
    Dec 2009
    Chichester
    218
    Take the sill trim off, lift the seal up around the window, remove the rear bench bases and pull. It takes a bit of wiggling but you'll get there
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Do a search on here for the Andymac sub. He uses the original space to fit a MDF box & bigger mini sub.
    The amp as I recall goes in behind the rear passenger panel.
    Does your car have Bose or not?
    ...... Now this one's MUCH better!...
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    I have the none bose soundsystem.
  1. Can i put 6x9 on factory amp Audi A3?
    By Nimosonen in forum The Welcome Section
    Last Post: 5th July 2013, 21:58
  2. Replies: 0
    Last Post: 28th April 2012, 22:47
  3. What is the wire wrap fabric tape that Audi use?
    By chrisash32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2010, 00:03
  4. Audi Factory Bose system, can i run an amp of this
    By dubhyper in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2006, 21:12
  5. Fitting Wiring Kit for EXTRA Amp? Easy? Drilling?
    By mspah in forum In-Car Entertainment
    Last Post: 4th April 2004, 09:25
Tags for this Thread
