JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Full lock clicking, but not the cv. HELP!!
    Hi guys, just bought myself a 2002 audi s3 (get some pics up soon). The other day my front left speed sensor went as my abs and traction lights came on, did an OBD scan and that flagged up, soon as it happend there is a clicking noise 3/4 to full lock Turning both ways, my dads a mechanic,did a road test and its not the cv as it does the same speed click no matter what speed you drive, it can stop and return in the same turn. What could be caused by this? Thanks.
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    image.jpg The 8L is my Audi, the 8p is my big brothers.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    870
    Add Vex182 on Facebook
    Possibly a track rod end of the power steering pump I guess, is it on full lock when it happens?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    It's more of an electrical clicking noise, coming from the passenger footwell/wheel. We had the wheel off and checked all the mechanical parts for movement,all okay. I think it may be a relay or somthing related to the wheel speed sensor. Happens on 3/4 to full lock.
    Dec 2012
    Manchester
    44
    Could it be the charcoal canister that's located just below the coolant tank? That clicks fairly loud now and then. It could be a coincidence that it starts to click when you're at full lock
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,411
    Quote Originally Posted by carld View Post
    Wrong side of the car.
    You've got to have a laugh!
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    loose hub nut?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    I don't think so ? It more of a plastic tapping, while in full lock it goes away then comes back, it's a soft noise, fit the new wheel speed sensor so if that fixes anything, I hope.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,411
    I was thinking of a damaged speed ring, which is easily done when fitting aftermarket wheels using to long bolts. That will coincide with your speed sensor issue. Maybe it's just the old speed sensor catching on it?
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    That's what I think it might be, a the speed ring was okay, and straight when turning, but the speed sensor plastic casing was hanging off before we touched it, I hope it was just the case that was catching.
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    It's sorted now, put the new speed sensor in, both the fault code disappeared and the clicking stopped, must of been a relay or somthing to do with the ABS
  1. Powersteering full lock squeal when stationary/slow movement - help!
    By kujo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2014, 09:10
  2. usual serpentinel belt squeak but not the tensioner!
    By woofdog in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2013, 20:08
  3. Drivers Side Footwells Swimming Pool - but not the plenum plugs
    By miniredcooper in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2012, 20:19
  4. S3 Alarm Problem, but not the batteries!
    By silver_mase in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2010, 17:24
  5. Replies: 3
    Last Post: 1st April 2008, 09:28
