AH FabricationsVolks Autos
Thread: breather pipe
    May 2013
    21
    breather pipe
    bought a honda s2000 are filter last week and last night I had time to fit it quite a simple job I thought.while I was doing this I un earthed some faults (not had the car long just sits in my garage) but the breather pipe on the rocker cover goes straight back into the tip.So under investigation realised its been taken off under the inlet manifold and left open, but rightly this should have a curved pipe with a black valve in im right, my mate works at tps so will order them on monday when hes back in work. just wondered what symptoms I would have got with this been like it was because engine was on, would it lose power? idle funny etc
    Mar 2013
    Chelmsford , Essex .
    223
    Hi , left open it will be a massive boost leak on turbo and a source of un metered air off boost so should have been causing all sorts of issues ! Mine had only split and caused random non starts , lack of power and terrible idle .
    check the rest of that crappy PCV system for perished / split hoses as you may as well sort any issues with one order
    baz
    1999 Silver 8L A3 1.8t sport (AGU) currently undergoing rolling modification
    pipercross panel , bosch super 4's , poly bushed front end , yellow dogbone , self refurbed 16" speedlines , ambient lighting.............TBC
    http://www.audi-sport.net/vb/a3-s3-f...ts-thread.html
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    It the car was used for sometime with that breather plugged directly into the TIP from the valve cover, then you have probably got oil in the turbo compressor, intercooler system, TB and manifold
    Get a new "hockey puck" or simplify the PCV system and fit a catch can.
  1. Oil Breather Pipe
    By Audi-Max in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2008, 11:22
  2. Breather Pipe?
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2008, 22:03
  3. S3 BAM - ESP/Oil Breather Pipes
    By jesters3 in forum Parts Requests
    Last Post: 18th July 2008, 17:26
  4. Breather Pipe
    By Bayleaf in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th July 2008, 19:16
  5. breather pipe part problem
    By fran-s3 in forum Tuning
    Last Post: 16th May 2008, 08:47
