Badger5Chris Nott
Results 1 to 14 of 14
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Smoke high end revs
    Hi all,
    Recently had a problem where when I give it some beans in 2nd/3rd/4th, and go over say 4000rpm, then change up, I get a cloud of smoke coming from the back, until I lift off..
    Any idea's what it could be?
    Edit: I should probably mention its a 1998 1.8T.
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    What colour is the smoke?
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Are you saying you're changing up before lifting off?
    Of do you mean you get the smoke as you lift off before changing up?
    Is the smoke white or have a blue tinge?
    I'm thinking broken or sticking piston rings, stem seals or turbo seals. Mainly blue smoke.
    ...... Now this one's MUCH better!...
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    I think it's black smoke. It only happens when I get high up into rev range then change gear, say pulling off slip road onto motorway. I'll be in 3rd @4000+ rpm, change gear and get a plume of black smoke. Then for the next few seconds there's a little more black smoke then it goes away.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Sounds like its throwing fuel in with black smoke...
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    What would cause excess fuel to be pumped through, or unburned fuel? Spark plug?
    What would be the signs of a turbo going bad? Would this do that? (the turbo has no issues as far as i'm aware but a friend said it could be that).
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    595
    What Dave said.
    Unburned fuel. Possibly a leaking injector...
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    On further inspection, the smoke is actually infact blue smoke.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Oil. Potentially either rings, turbo seals, or your PCV system. Worth whipping the hose to the TB to see how oily it is.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    It's happened again. I got to about 4000r/pm, and then all of a sudden lost power and plumes of blue/white smoke everywhere.
    Lifted up bonnet too and, from the back of the engine (where the turbo is situated) the same colour smoke was seeping out.
    Anyone got any ideas?
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Quote Originally Posted by S3quatt View Post
    turbo seals.
    Quote Originally Posted by Sam_ View Post
    turbo seals,
    Quote Originally Posted by Spatula View Post
    ... plumes of blue/white smoke everywhere...
    ...and from the back of the engine (where the turbo is situated) ...
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Lol, fair enough. Is it a hard job to get done? I guess it's a garage job at very least.
    Is there any way to make sure that's the problem? like, compression tests etc.
    Cheers,
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Not sure how to definitely confirm it, best off speaking to Dan ( beachbuggy), he'll know
    a standard garage is likely to subcontract a job like that out to a specialist, which Dan is
    Alex S3 AMK
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    Okay cool. I've messaged him. I'm thinking if it IS a turbo issue, I might just replace with a KO3S.
    Why is it a bad idea to buy one of the copies?
  1. high end car audio
    By dann1701 in forum For Sale/Wanted - Miscellaneous
    Last Post: 19th July 2011, 22:39
  2. black smoke at high revs?
    By Bev_B in forum Diesel forum
    Last Post: 21st April 2009, 07:31
  3. Remapped S3 losing boost high end
    By dgannon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2009, 22:17
  4. 2.5 tdi - smoking at low revs -no power loss...ideas ?
    By nicknick in forum Diesel forum
    Last Post: 28th February 2009, 17:34
  5. S4 white exhaust smoke only at high revs
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2007, 20:41
