Sky InsuranceAH Fabrications
    Sep 2012
    61
    Excess oil around erg value.
    Ok, so long time no talk from myself, been busy with work and after a bwm thought it would be a good idea to drive into me followed by a stone cracking the windscreen. And autoglass not playing fair.
    I have just noticed a lot of excess oil around the top of the engine but it does not look like a gasket has gone anywhere, would any one have any idea where this would be coming from?
    Any help would be welcome or idea's.
    Mar 2013
    Devon
    611
    Looks like one of the EGR seals has gone.
    The oil is originating from the crank case breather, traveling round the boost pipework and making its way out around the egr.
    The erg valves on the diesels need cleaning every so often anyway, so I would remove it and and clean it inside and out.
    When re-fitting replace the gasket between it and the exhaust feed, the o-ring between it and the inlet manifold and the seal on the 90 degree charge pipe that connects into it
    Hopefully that will stop your leak, if not then with the area cleaned up it should be easier to see if it is leaking around the vacuum diaphragm or elsewhere.
  1. Oil Around The Filler Cap - PCV Valve / Filter
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th August 2010, 01:47
  2. Excessive Oil Consumption.........
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2009, 18:22
  3. Excessive Oil Filter Pressure??
    By Sm[]key in forum Diesel forum
    Last Post: 30th March 2007, 21:14
  4. oil around DV??
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2006, 14:46
  5. Excess Oil Usage ??
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2003, 22:38
