Volks AutosMonster Motorsport
Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
Like Tree15Likes
Thread: Gordie's S3 Thread
  1. #41
    Gordie_S3's Avatar
    Feb 2013
    Melbourne, Australia
    78
    So out went the crappy annoying TA technix coilovers which have leaked out oil, and physically bent...and in went the KW V3's with silver project camber tops. Such a change in a ride quality, very please with them...nice firm ride. Still have to learn how the damper/rebound works and what effects they have on the car though. Can't wait to hit up the track!
    s3dave and Sam_ like this.
    Stage 2 S3 8L + other mods
  3. #42
    Gordie_S3's Avatar
    Feb 2013
    78
    Not much has been happening here since the coil overs went it.
    Took the rear seats out for weight reduction, was surprised how heavy they are!
    -Silver project camber tops are in. Pretty happy with them, no noise/knocks.
    -Painted stock wheels in satin black.
    Next up on the list
    - Slotted/drilled discs
    - EBC red stuff pads
    - Braided lines
    - Fluids
    - 235/45/17 Kuhmo ku36 semi slicks
    - 25mm spacers
    Hitting up my first track day with it on the 29th September!
  4. #43
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I'd stay away from the drilled discs fella...there prone to crack with the extreme temperature changes they have to cope with.
    Just stick with slotted ones and if you can stump up the extra dosh go for DS2500 pads
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  5. #44
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Have you had all the alignment sorted? Mad a massive difference on mine getting all the camber and castor sorted. That and changing all the bushes replaced/upgraded.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  6. #45
    Gordie_S3's Avatar
    Feb 2013
    78
    Quote Originally Posted by kwistof View Post
    There not drilled all the way through, will it still be a issues?
    Drilled Slotted Audi S3 2000 2002 Front Disc Brake Rotors RDA7214D Pair | eBay
    Quote Originally Posted by Sam_ View Post
    Nah not yet, I'll sort it out before I hit the track.
  7. #46
    Gordie_S3's Avatar
    Feb 2013
    78
    Took her down to a local dyno day that was held today..
  8. #47
    Gordie_S3's Avatar
    Feb 2013
    78
    Time for a update!
    Fitted slotted and drilled discs rotas, EBC red stuff pads, braided lines all around and ATE racing blue dot4 fluid.
    Also, got around getting some OZ saturn wheels for $250 locally, then got around getting some Kumho KU36 semi slick for it, just in time for my first track day!
    Had a few issues blew open the silicone turbo outlet pipe, which is a worry...I thought they good against heat? Lucky a friend of mine drove his s3 on the day, and used the his OEM so I could keep going throughout the day.
    Popped a bottom intercooler hose off as well during a session, easy fix!
    At the end of the day I noticed a lot of oil pissing out of the catch can, is this normal? I lost quite abit of oil due to this. High oil pressure in the head?
  9. #48
    Dan
    Sep 2013
    Manchester
    9
    Love it, looking really good with some sweet mods.
    Cam i ask where you got the downpipe from? Looking for one myself at the moment.
  10. #49
    Gordie_S3's Avatar
    Feb 2013
    78
    Update - Got her some Enkei RPF1's, 18x9.5 all around with spacers to clear the coilovers.
    Also, took the engine out of the car, sold off all the ko4 gear! Stroking the motor to 2008cc with a GT2871R
    - Mahle powerpack 83mm 9:1 CR pistons
    - TFSI 92.8mm crank
    - Pauter H beam rods 144x20mm
    - ATP T3 manifold, custom downpipe
    - 1000cc injectors
    Pics up next week of the parts, still waiting for them to arrive from QLD
    as it sits at the moment
    s3dave, Rice and dj_rzn like this.
  11. #50
    Oct 2012
    South Africa
    268
    One of the hottest S3's on here.
    Love your work!
  12. #51
    Gordie_S3's Avatar
    Feb 2013
    78
    Thanks dude! You're S3 is looking very classy too.
  13. #52
    Gordie_S3's Avatar
    Feb 2013
    78
    IE torque plate
    JE pistons - with Tuff Skity coatings and JE steel wrist pins
    ARP main studs and ARP head studs kit
    Sam_ likes this.
  14. #53
    Gordie_S3's Avatar
    Feb 2013
    78
    FX450 is in, aswell as main bearings and rod bearings.
    Sam_ likes this.
  15. #54
    Gordie_S3's Avatar
    Feb 2013
    78
    Block is off to get bored out and decked. crank and the bottom end are off to get balanced and linished.
    Had to swap over the oil gear from my old 1.8t crank to the FSI to prior to this.
    <tuffty/> and Sam_ like this.
  16. #55
    Gordie_S3's Avatar
    Feb 2013
    78
    More parts
    - Integrated engineering oversize gasket kit
    - Mocal oil cooler kit
    - More IE goodies
    Should get the bottom end back next week from machine shop, getting the crank gear dowelled too which has delayed the balancing by a few days.
    Sam_ likes this.
  17. #56
    BrennanTDi's Avatar
    Events Moderator
    May 2014
    Northern Ireland
    536
    Great looking car, also love that bora
    A4 B8, 19" AVA Memphis, 35mm APEX, LED DRL
    Northern Ireland/Ireland Events Moderator... Click >>here<<
    -- Photoshop Guru... Requests Click >>here<<
  1. Subjects and Threads
    By Mutley in forum A8/S8 forum
    Last Post: 7th August 2003, 23:43
  2. Thread deleted
    By Administrators in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2003, 13:42
