EM TuningChris Nott
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By beachbuggy
Thread: Engine damage
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Engine damage
    My mates TT 225 has died. So been helping him investigate the cause. Compression test showed cylinder 3 with a low compression.
    So we pulled the head off in hope that it was an issue with the valves. But not such luck.
    Found cylinder 2 & 3 to have some damage to the pistons. All the pistons have evidence of contact with the valves but I think this happen before he bought the TT, as he has an invoice for some work done to the head and there is no damage to the valves now.
    The pcv system is also poked, as there is a lot of oil in the intake system and throttle body is pretty dirty.
    There were some random bits of metal inside the cylinder that has been beaten around with the 3rd cylinder taking the most damage.
    Anyone have any ideas of what's happened?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,451
    The top of cylinder 3 looks like a milder version of mine. Ive since found my sparkplug destroyed and have now come to the conclusion that the ceramic broke up, smashing around the bore causing detonation.
    Its a bit of a stab in the dark finding out what causes these things
    beachbuggy's Avatar
    Surrey
    1,727
    That's had a cam belt failure at some stage and dented the pistons..
    S3quatt likes this.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    Quote Originally Posted by beachbuggy View Post
    My thoughts straight away. Looks like valve impacts.
    How do the bores look?
    Scored at all?
    ...... Waiting Paitently...
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Looks like they never bothered to flatten and polish the collision marks and so caused further detonation/hotspots..
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Yeah,definitely had some love from the valves. Head and valves are ok, them BAM marking has been filed off so I am assuming someone did a quick fix with another 20v head and bolted it on then sold the car on.
    cyl 3 has some scoring nothing serious but will need a rebore and some 82mm pistons.
    TT owner has decided it needs a rebuild with some rods and a stage 2 with wmi. Maybe a k04 hybrid later down the road, I will have to keep working his rubber arm
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    564
    Quote Originally Posted by Scullies View Post
    Win Win then!
  1. Engine damage
    By G60DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2011, 11:23
  2. A4 Complete Engine damage- Bck on tha Rd
    By Steve N in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2008, 01:32
  3. Audi A4 2001 1.8t Complete Engine damage
    By Steve N in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2008, 12:59
  4. Pictures of my damaged engine
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2007, 11:11
  5. can too much coolant damage the car/engine?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 17:32
