EM TuningSky Insurance
Results 1 to 14 of 14
    Nov 2005
    UK
    12
    Noob needs \"Check Engine Light\" help
    Hi,
    First post - please be gentle.
    I have a 2002 1.8 T Sport A3.
    For the last few months my check engine light has been on and off.
    I took it back to my independent mechanic last week.
    Bascially it is coming up with the same codes. The codes he describes as "long term codes" that don't really need any specific attention until the car starts running badly.
    He reset the light, then the next day it was on again.
    Is there any way I can avoid
    a) paying this bloke 30 to turn the light off and give me the same advice every week
    b) avoid paying a $1000 for VAG-COM and the lead to clear the codes my self.
    I'm thinking of selling the car privately next year, but in the meantime I want to be sure that the light isnt giving out different codes in the interim.
    Hope that makes sense.
    I've seen these things for 30 quid on ebay from China - do they work?
    Ive also seen people selling leads on ebay for use with VAG-COM - but as i read it this is just for use with the shareware version of the software and this version cannot reset the check engine light.
    Many Thanks - and hello to you all
    Geoggy.
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Re: Noob needs \"Check Engine Light\" help
    u can disconnect the battery and it should wipe the light out
    as for the reason for the error codes, you will have to find someone with Vag-com who is kind enough to check it for you
    Nov 2005
    UK
    12
    hi mate,
    will disconnecting the battery cause any problems elsewhere?
    thanks
    G
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    no probs at all - leave it about 20mins before you reconnect
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    It would be good if you could get the actual error code from the garage. It might be a very quick fix.
    If we have the code then it will help to diagnose for you.
    Nov 2005
    UK
    12
    ive got the codes at home. i'll post them tonight.
    thanks
    Oct 2003
    South Wales
    2,942
    Let us know your location and perhaps you could meet up with someone who is local to you off this forum... Lots of people on here have vagcom..
    Jul 2003
    Essex
    358
    the engine light will automatically go out by itself. I cant remember how many key revolutions are required before it resets itself. If the fault has gone the light wont re-appear. Obviously you will have to deal with the problem first to find out what is triggering the light.
    Nov 2005
    UK
    12
    Hi,
    I am based in St Helens, Merseyside (about 12 miles from Liverpool)
    The codes are:
    17545
    Engineers Description :
    Bank 1 Long term fuel trim system too rich
    17705
    Turbo / throttle valve connection pressure loss
    He's then witten
    "Also headgasket problems"
    Although i would like a second opinion on that given that ive done only 38,000 miles in the car.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    17545 means your fuel mixture is a bit too rich at idle.
    I would hazzard a guess at this being a prob with the lambda probe that sits in the exhaust pipe after the catalytic convertor.
    Either the connection to it is bad or the probe is faulty itself.
    17705 can be simply be caused by a dirty throttle valve. But its also linked in with the lambda stuff.
    If you can find someone in your area with vagcom then I'll post the steps to check the lambda control, but swapping the probe may sort it.
    Nov 2005
    UK
    12
    thanks mate.
    how much are we talking for a dealer to swap the probe?
    thanks
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Probe is about 100 from Audi (probably get it cheaper from www.vagparts.com or www.gsfcarparts.com}
    The probe is really easy to get to so I wouldn't want to pay more than half an hours labour plus the clearing of the fault codes.
    Nov 2005
    UK
    12
    after reading this mate, http://www.briskoda.co.uk/forums/sho...d.php?p=239049
    Its a bit old, and it relates to a Skoda, but they are the exact same two codes and replace of a "dump valve" sorted the problem. (these are 15 quid on that vag parts site you posted.
    what do you reckon?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Sounds interesting and definately worth a try. Usually if there is a fault with the DV you get the code that says "mechanical fault N249, Check DV!"
    But it would be a very cheap and easy fix to replace the DV first as they are only something like 25 from the dealer. (make sure you get the later stronger revision of the valve. Part number : 06A145710N)
    If your car isn't chipped and you get a fluttering sound from the engine when you change gear whilst driving hard then this would also indicate a broken DV.
