EM TuningBadger5
    Mar 2013
    Chelmsford , Essex .
    223
    spigot bearing ?
    evening
    my dual mass is making some awful noises so it's smf time :D
    now the kit im looking at VOLKSWAGEN VW GOLF 150 1.8 TURBO AGU, ARZ, AUM SOLID FLYWHEEL & VALEO CLUTCH | eBay
    comes with flywheel , cover and plate , release bearing and cover and flywheel bolts .
    there is NO mention of a spigot bearing included or needed !
    do AGU'S run / need a spigot bearing either before or after a smf conversion ?
    baz
    1999 Silver 8L A3 1.8t sport (AGU) currently undergoing rolling modification
    pipercross panel , bosch super 4's , poly bushed front end , yellow dogbone , self refurbed 16" speedlines , ambient lighting.............TBC
    http://www.audi-sport.net/vb/a3-s3-f...ts-thread.html
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    058 blocked 1.8t's (inline engines) do but 06A blocked 1.8t's (transverse engines) don't...
    <tuffty/>
    Mar 2013
    223
    sorry paul im a numpty :0
    does that mean no i dont have or need a spigot bearing ?
    sorry
    baz
    Scullies's Avatar
    Feb 2012
    Dubai
    1,239
    Afaik the spigot/pilot bearing is not used in transverse engines., its used in longitudinal engines.
    I did used one in my rebuild as it helps align the clutch when using the alignment tool that is supplied with my clutch kit.
    My FSI crank (RIP ) had a pilot bearing but it came out of a longitudinal engine in from an A4
    You don't need it.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    No transverse engine I have ever worked on has a spigot bearing so I would say no you don't (unless there is some random variant that does... I am no expert tbh...)
    I have only ever seen a spigot bearing on A4's etc, never on cars like Ibiza's, Leons, A3/S3 and TT's...
    <tuffty/>
    Mar 2013
    223
    <tuffty/>
    blimey , you do a very good impression then
    thanks chaps , i didnt want my daily on axle stands on the drive on a sunday afternoon disabled due to a two bob bit i didn't have
    cheers chaps
    basil
  1. IHI Roller bearing turbo
    By RichA3Turbo in forum The Project Room
    Last Post: 14th August 2009, 11:52
  2. Guide Pins & Wheel bearing housing
    By neversaydie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 21:56
  3. Just had bearing arms replaced - FORKED OUT!!
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2004, 20:52
  4. Wheel Bearing (Spelling?) noisy
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2004, 17:34
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
