JMB RetrofitsSky Insurance
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By craigynett
Thread: key fob problems
    matt blowen's Avatar
    Jul 2013
    staffordshire
    137
    Add matt blowen on Facebook
    key fob problems
    hi there, i have a 3 door audi a3 1999 1.8t which i recently bought, it only come with 1 two button key fob. problem is the buttons do nothing, i have replace the battery with a 2032 batt. i have tried most re sync combinations with no luck!! when i unlock the car i have to put the key in the ignition to unlock the boot and passenger door else the hazards flash repetedly. I have plugged vcds in to find faults with the convienience module but when i try to open the contoller it states 'no responce from controller' does this car have one? i have fault code of 01134- Alarm horn (H12) 49-00 -no communications... any help would be appeciated thanx.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Try ' 35 central locking ' with vag com and clear all faults
    Your sirens knackered for starters as it should sound with the indicators
    Could be it just needs syncing or re coding or it may be the wrong fob
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Jul 2013
    staffordshire
    137
    Hi thanks for the reply, ive cleared all codes but that 01134 keeps popping up! How would i no ive got the wrong fob? Also ive tried a load of re syncing ways but none seem to work.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,242
    I knows it's a dumb question, but did you use the correct battery in the fob? I recently changed my battery and found I needed 2x 1620 batteries in my fob. I have a 2001 s3 so maybe things at different
    Jul 2013
    staffordshire
    137
    Ha ha good question it used to have 1 2032 so i replaced i with a new 1, ill try what you sudgested thanks
    May 2012
    RETFORD, NOTTS
    1,749
    do you have any way to check the fob is emitting a signal? if you was local i would be able to sync a spare fob to your car unless there is an issue with your modules. Im breaking an a6 if the parts are interchangable?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2013
    staffordshire
    137
    Hi @udi a3 may live too far away, i have used vcds to check for a signal in measuring blocks but it reads no signal, so i dont know if its the fob or the receaving unit? Also reading other post somebody tried doing what i did with a working fob but it didnt show no signal either.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Fob should have a part number inside?
    Pump seems to be behaving properly so fob would be my guess either not coded or completely wrong
    Where about in staffs are you?
    kev
    90 eunos roadster
    Jul 2013
    staffordshire
    137
    hi im in Cannock, I thought it might be the fob, I have ordered a used fob, don't no if it'll do the trick but at least I can check if its the correct battery, I cant find the part number on my knackered fob (last owner must of super glued of it !!)
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    I'm only down the road then in brereton
    If you get a blade cut I can program the key if you need it doing
    kev
    90 eunos roadster
    Jul 2013
    staffordshire
    137
    Hi old_kool thanks for that m8
    Jul 2013
    staffordshire
    137
    bump! just received my new key, its from a s reg s3 and it has different internals im guessing this isn't gunna work?
    May 2012
    RETFORD, NOTTS
    1,749
    Was this just for a spare key? Instead of buying several fobs thinking they are correct you need to check the part numbers and buy from a reputable seller, preferably new. its going to be a little more expensive, but clearly less troublesome.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    What's the part number of the new key
    If it definitely came from an 8L it should work there all the same
    kev
    90 eunos roadster
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    1999-2002 3 button remote part number is 4d0837231 a or n
    1997-2000 2 button remote part number is 4d0837231r
    there's several other Audi remotes that look the same but have different part number & aren't compatible
    @udi A3 likes this.
    Please contact Admin if you wish to advertise your business/services on the forum
    Jul 2013
    staffordshire
    137
    the fob I bought was 4DO 837 231 and was two button with 2 batteries and my crappy fob has two buttons and one battery ive tried everythink I can think of to link it up, might take my car to timpsons (key specialist) and see if they can sort it out
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Bring it round to me I've been playing with these pumps and fobs for years
    I'll pm you my number
    The one you bought should be correct by the way
    kev
    90 eunos roadster
    Jul 2013
    staffordshire
    137
    finally cracked it, used vcds 35, channel 21 new value 1 then hold unlock button for 1 second on each fob. so happy now, thanks for all your help
  1. Key fob problems
    By Essflee in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 24th April 2013, 17:39
  2. Key Fob problem - Not locking or unlocking
    By a3tazza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2012, 01:16
  3. key fob problems!!!! need help
    By Mcblow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd July 2010, 14:45
  4. New key fob problems
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th April 2010, 11:44
  5. Key fob problem
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2010, 20:54
