Sky InsuranceEM Tuning
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    What oil cooler and fittings do i need?
    Hi Guys, as above does anyone know what size mocal oil cooler can I get in above AH front mount. Also what size sandwich plate, fittings and hose do I need. Any help would be greatly appreciated.
    2002 S3 8L, BAM, 85,000m, B5 map, B5 tip, K04, small port head, jetex filter & heat shield, Xs mani v3, 3" d/pipe, 200 cell cat, miltek non res cat back system, Sachs DMF & 4 paddle clutch, PCV delete & catch can, N249 delete, AH fab v2 intercooler, silicone boost hoses, Liquid gauge, LCR Brembo's, DS2500 pads, Braided brake lines, Motul RBF600 brake fluid, LED bulb kit, aero wipers, manifold heat shield, Aquamist WMI, Mocal oil cooler, Forge short shifter, Dave's rear tie arms. 295bhp/274lbft.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    As far a I know nobody has fitted a mocal above an AH FMIC. My 13 row cooler only just squeezed in above my toyosport (Welly) FMIC.
    I think SuperKarl kindly measured and took photos of his cooler in another oil cooler thread.
    As for fittings all you need is on "MLR" Matt Lewis Racing on eBay. He even does the full kits. Drop him an email if you need any further help as he's pretty helpful.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Search bar = thread filled with fittings, coolers, sizes, parts youl need.
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    Cheers Westy will give him and bell and look for superkarl's thread.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    what would help the original oil cooler thread that i started and westy contributed to hugely, is if you measure the space you have above your fmic. As yet no one has fit one above an AH cooler, only a wellycooler, which a 13 row fits with the dimensions i gave in that original thread.
    If you can go some measuring, cross reference with our cooler measurements, that would be really helpful to some people.
    Simon_S3's Avatar
    Dec 2012
    West Sussex
    89
    Thanks Karl and Westy for the advice, will take bumper off and do some measuring. Like you said it may help some others out if they go down the same route.
  1. what fitting do i need for my oil feed (engine side) gt28 71r
    By jonno123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2013, 12:55
  2. what oil do I need to use?
    By john_cook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2006, 06:49
  3. A guide needed what to do with Fitting a Alpine Head unit in my A4
    By Rev-head in forum In-Car Entertainment
    Last Post: 3rd September 2006, 00:06
  4. Is there a valve in the oil filter and cooler?
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 12:44
  5. Newbie saying Hi .. and what oil ?
    By Stormin1977 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th November 2003, 09:06
