AH FabricationsEM Tuning
Results 1 to 12 of 12
    Oct 2011
    760
    alignment amd essex
    Hi all
    Just been to amd essex for 4 wheel alignment.
    heres the results.
    im not happy with the front camber.
    The tech told me my front hub or strut is bent. hmmmm
    I didnt think the camber could be adjusted that much? (front left)
    I asked for 0 toe front and rear. The front i can live with, the rear is adjustable tie arms time (more money)
    The front has just been totally poly bushed and the rear trailing arms and anti roll bar poly bushed.
    Am i being had?
    Any thoughts or suggestions welcome.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    front camber and toe is completely adjustable to whatever you want really, unless things are bent.
    rear camber adjust needs rear tie arms.
    rear toe is adjustable as standard but not by much, combined with adjustable camber arms and you can get a bit more however.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Whats he written at the bottom?
    If somethings bent, it could be the damper, wishbone, hub carrier or the subframe itself.
    TD5 Land Rover Defender build
    Oct 2011
    760
    Heres a link to see diagram straight.
    4wheel_zps33872ab5.jpg Photo by jezzy114 | Photobucket
    "Stick a V8 in it!"
    15,379
    its still cropped so you cant read what hes written at the bottom..
    Oct 2011
    760
    The bottom says non adjustable rear camber arms, suspect front hub and/or damper bent, currently at limit of camber adjustment and subframe moved.
    Thanks for the replies so quick
    "Stick a V8 in it!"
    15,379
    Yeh so they've even tried moving the subframe to get the front camber fixed so something must be bent.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    rhubarb on hear had a bent subframe, theyre flimsy in the grand scheme of things, when compared to the wishbones which are cast.
    your caster is fairly even though, so that would suggest the subframe would be bent directly inward.
    Oct 2011
    760
    Thanks much appreciated.
    This car is killing me, good job i love this *****
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    haha. best thing to do would be get it on a ramp and really thoroughly inspect it. If you cant immediately see anything, take pictures of things regardless.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    They couldn't adjust the camber by sliding the ball joints on the front? just over 2 degrees is quite a lot tbh even with the ball joints pulled right out on mine I think I managed just under 1.4 degrees... mine are settled on -1.3 degrees IIRC as this was the best that could be done with the combo of subframe and ball joint manoeuvring on my 30mm drop...
    You will get more neg camber the lower you go, how low is your car?...
    Does look like something could be out though... you do have a small amount of movement in the subframe but its not loads... certainly don't think its a degree or so assuming your subframe is all the way over to the left
    <tuffty/>
    Oct 2011
    760
    Subframe check on wednesday my day off.
    Will check to see if theres movement on the subframe or ball joints.
    just seems all the camber is on one side
    Thanks for the reply
    Car is low
  1. Hunter Hawk Eye Four Wheel Alignment at AmD Essex
    By ben@amdessex in forum Sales Questions
    Last Post: 22nd May 2012, 17:11
  2. Exciting News at AMD Essex
    By ben@amdessex in forum News & Latest Offers
    Last Post: 23rd January 2009, 18:46
  3. Just come back from AmD Essex - 330bhp anyone? (pics)
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2008, 23:00
  4. Free Fitting on Sachs Clutches from AmD Essex.
    By shaun@amdessex.com in forum News & Latest Offers
    Last Post: 9th September 2008, 16:30
  5. AmD Essex Rolling Road Clips
    By shaun@amdessex.com in forum You Tube Links
    Last Post: 19th March 2008, 21:54
