Badger5Sky Insurance
Results 1 to 7 of 7
Thread: New Clutch disc
    Sep 2011
    Scotland Dumbarton
    246
    New Clutch disc
    Well it seems my clutch is on its way out again! for reference im running an S3 with 305bhp and roughly 300lbsft of torque, ive been looking at sachs performance puck clutches but there doesn't seem to much info on google about other alternatives that don't have to imported from the states, im only looking for the disc not a full clutch kit anyone got any ideas?
    cheers
    liam
    Noggy blue Bam engined S3. Complete with cr turbos stg4 turbo, xspower mani, dp and sports cat, rifle drilled IE rods, 550 injectors, forge 007, badger5 v2 tip, jetex with heatshield, wellycooler, catch can, weitec lowered shocks +springs, 15mm front 20mm back spacers, rtech custom map
    304bhp 290lbsft wmi soon to be fitted along with 986 brembo fronts!
    Jan 2011
    northants
    165
    would only fit a kit mate as it is probably the pressure plate not man enough for the job
    i would recommend a helix kit but they are not cheap
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    I use a Sachs paddle and LuK DMF... DMF you can get from GSF/ECP, Sachs paddle plate from Bill and use a std LuK S3 clutch kit for the cover plate..
    <tuffty/>
    Jul 2011
    57
    Add S3_DAVE on Facebook Visit S3_DAVE's Instagram Channel
    how much roughly did you pay for this setup tuffty?
    loving your thread and car btw... what a beast!
    Apr 2011
    Dublin, Ireland
    621
    I purchased this last week. Sachs clutch disc cost £250 from badger and the standard luk kit cost 160euro. I did not replace the flywheel as it was not needed.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    Sep 2011
    Scotland Dumbarton
    246
    <tuffty/>
    Tuffty would a Sachs pressure
    plate work, as that's what I've got on the car just
    now. I'll be buying the same flywheel as Andrew at some point for when I finish my stroker build but need something in the short term to make driving the car decent? Need to get in touch with Bill soon with regards to the clutch disc.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by sandwich1987 View Post
    Arguably yeah... I used this setup as it feels more OEM... its a light pedal but still mega grippy and handles all I have thrown at it... the plate is designed for an OE setup so as long as your cover is too then all should be fine
    <tuffty/>
  1. New Clutch
    By imported_5xi in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd January 2005, 20:07
  2. new clutch needed after remap??
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2004, 17:24
  3. New Clutch Price?
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2004, 19:29
  4. My mk IV Anniversary....new clutch?
    By Pacman in forum Volkswagen and other VAG
    Last Post: 16th February 2004, 13:59
  5. New clutch sorted and cheap !
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2003, 11:31
